Consider a string with both ends fixed. If somewhere in middle of it be pulled and released, how would it oscillate and what is it's equation?
My solution assuming the result is a standing wave:
The point which is pulled will be an anti-node, so the length of string before this point is $(2n-1)\times\frac{\gamma}{4}$ and the length of string after this point will be $(2n^\prime-1)\times\frac{\gamma}{4}$. Considering the first length $l$ and the second length $l^\prime$, we will have: $$\frac{2n-1}{2n^\prime-1}=\frac{l}{l^\prime}$$ So the oscillator will be in it's $n+n^\prime -1$ harmonic. But what if that equation doesn't have natural answer, and what if it has answer so double of that is still an answer?
Mathematically the shape of the string is the superposition of multiple standing waves. In general it has the form:
$$ y(x,t) = \sum_{i=1}^{\infty} \sin \left(i\frac{ \pi x}{\ell} \right) \left( A_i \sin \left( i\frac{ \pi c t}{\ell} \right)+ B_i \cos \left( i\frac{ \pi c t}{\ell} \right) \right) $$
where $\ell$ is the length from end to end, and $c$ is the speed of wave propagation along the string.
Now given an initial pluck of the string, of triangular shape you find the coefficients $A_i$ and $B_i$ using Fourier transform. The result is:
$$ \begin{align} A_i &= 0 \\ B_i &= Y \frac{2 \ell^2 \sin \left( \frac{i \pi x_p}{\ell} \right)}{\pi^2 i^2 x_p (\ell-x_p)} \end{align} $$
where $x_p$ is the position of the pluck point, $Y$ is the pluck amplitude, and $i=1 \ldots \infty$
To arrive at this use the pluck shape $y_0(x) = Y\,{\rm if}(x \leq x_p, \tfrac{x}{x_p}, 1-\tfrac{x-x_p}{\ell-x_p})$ and the known initial conditions $$ \begin{aligned} \lim \limits_{t\rightarrow 0} y(x,t) & = y_0(x) = {\rm triangle} \\ \lim \limits_{t\rightarrow 0} \frac{\partial}{\partial t} y(x,t) & = v_0(x) =0 \end{aligned}$$
Now pre-multiply with $\sin\left(i \frac{\pi x}{\ell} \right)$ and integrate over the length of the string
$$ \begin{aligned} \int \sin\left(i \frac{\pi x}{\ell} \right) y_0(x) {\rm d}x &= \int \sin\left(i \frac{\pi x}{\ell} \right) \lim_{t\rightarrow 0} y(x,t) {\rm d}x = B_i \frac{\ell}{2} \\ \int \sin\left(i \frac{\pi x}{\ell} \right) v_0(x) {\rm d}x &= \int \sin\left(i \frac{\pi x}{\ell} \right) \lim_{t\rightarrow 0} \frac{\partial}{\partial t} y(x,t) {\rm d}x = A_i \frac{i\,\pi\, c}{2} \end{aligned} $$
or
$$\begin{aligned} A_i &= \frac{2}{i\,\pi\,c} \int \sin\left(i \frac{\pi x}{\ell} \right) v_0(x) {\rm d}x = 0 \\ B_i & = \frac{2}{\ell} \int \sin\left(i \frac{\pi x}{\ell} \right) y_0(x) {\rm d}x = \frac{2 Y \ell^2}{\pi^2 i^2 x_P (\ell-x_p)} \sin\left(i \frac{\pi x_p}{\ell} \right)\end{aligned} $$
John Alexiou
  • 40,139
