I’ve been told that electron capture occurs when there isn’t enough energy to produce a positron by beta plus decay. Exactly why is this the case? Why does it take more energy for positron emission than electron capture?
Electron capture:
$p+e^-\rightarrow n+\nu_e$
Beta plus decay:
$p\rightarrow n+e^++\bar{\nu_e}$
Let's check the masses of both sides of the processes:
Electron capture, initial state: $m_p+m_e=938.78 \frac{MeV}{c^2}$
Final state: $m_n=939.56 \frac{MeV}{c^2}$
The difference: (Final minus initial) $0.78 \frac{MeV}{c^2}$
Beta plus decay: (Positron emission)
Intial state: $m_p=938.27 \frac{MeV}{c^2}$
Final state: $m_n+m_e=940.07 \frac{MeV}{c^2}$
The difference: (Final minus initial) $1.8 \frac{MeV}{c^2}$
You see that you need to add more energy in order to do beta plus decay than to capture an electron.
Also note: A free proton can't emit a positron and turn into a neutron, but a free proton can capture an electron.
- 1,355
this is not true, EC only happens in many p's and many n's atoms.
but free p can only have positron emmision for a weak interaction, or the sun will burn too fast if it is done by EC {electron capture}
- 1
