10
We know that the electric field for a point charge is $$ E = \frac{KQ}{R^2}. $$ If $R$, i.e. distance from the electric field producer to the point where we want to find the electric field becomes zero, then $E$ will tend to infinity. Now take a case where you have a uniformly charged sphere and you need to find the electric field on the charged sphere. The charged sphere is not a point charge, its rather a combination of point charges. What is electric field at any point, say $P$, on the charged sphere?
Now we know that when we use Gauss's Law, we select a Gaussian surface in such a way that all the points on the Gaussian surface should experience same electric field. Many sources say that if we use Gauss's Law then on any point on the charged sphere the electric field is going to be $$ E = \frac{1}{4\pi\epsilon_0}\frac{Q}{R^2} $$ where $R$ is the radius of the sphere and $\epsilon_0$ is the permittivity.
But now, don't consider Gauss's Law. As $P$ is at the surface of the charged sphere, then the electric field due to the small element of the charged sphere on which point $P$ lies is infinity, as the small element has charge $dq$ (let's also say we have assumed the small element of charge $dq$ on which point $P$ lies to be a point charge, and hence $R$ becomes zero, as the point $P$ lies on the small element). So electric field must be infinity due to that small element on which the point P lies. It doesn't really matter how much small the charge of the element is! When you do divide a large number and zero, you get infinity and similarly when you divide a very very small number and zero, you will again get infinity. Now for rest of the small elements which make up the whole sphere, the electric field won't be infinity; instead it would be some finite value. Say on the point $P$ for all the other small elements (except the element on which the point $P$ lies) net electric field is $X \rm\,N/C$. Still, $\text{infinite}+X = \text{infinite}$.
From here we conclude that on the point $P$ the electric field must be infinite. Then how did we get $$\frac{1}{4\pi\epsilon_0}\frac{Q}{R^2}~?$$
My second question is: Similarly how can one say that we can find the potential on the surface of the charged conductor? I saw sources saying that the potential on the surface of the charged sphere is $V=KQ/R $ if $R$ is the radius of the sphere. But how is this possible? I mean on the surface again for the above reasons we would get it to be infinite!
Please explain these doubts to me. These might be silly doubts, but still. I don't know how far my thinking is correct.
Krishna behera
  • 133
5 Answers5
(Other) Rob's answer seems good to me, but let me offer another way of thinking.
As you approach the surface of the sphere very closely, the electric field should resemble more and more the electric field from an infinite plane of charge.
If you check Gauss's law (recalling that the field in the conductor is zero) you will see that if the surface charge density is $\sigma=Q/4\pi R^2$, then indeed the field at the surface is $\sigma/\epsilon_0$ as in the infinite charge of plane case.
Such a field is constant, the field lines are parallel and non-diverging, and the infinities associated with the field due to point charge do not arise.
ProfRob
  • 141,325
For a charge distribution $\rho({\bf r'})$, the electric field at ${\bf r}$ is $${\bf E}({\bf r})=k\iiint\frac{\rho({\bf r'})}{|{\bf r}-{\bf r'}|^2}\hat{\bf R}d^3{\bf r'}$$ where ${\bf R}={\bf r}-{\bf r'}$.
I think the OP's claim is at positions where $\rho \ne 0$, the above integral is infinite because the integrand blows up at ${\bf R}={\bf 0}$.
I think the OP should first ask yourself whether you are asking a mathematics question or a physics question.
If you are asking a mathematics question, I think your question is similar to whether $$\int_0^1\frac{1}{\sqrt{x}}dx$$ is undefined (or infinite according to your argument), or equals $2$.
In my opinion, strictly speaking, the above integral is undefined, because the integrand is undefined at $x=0$.
However, since $$\lim_{\epsilon\rightarrow0^+}\int_\epsilon^1\frac{1}{\sqrt{x}}dx=2$$ we usually just say $$\int_0^1\frac{1}{\sqrt{x}}dx=2$$
So in my opinion, when we write $${\bf E}({\bf r})=k\iiint\frac{\rho({\bf r'})}{|{\bf r}-{\bf r'}|^2}\hat{\bf R}d^3{\bf r'}$$ we are actually saying $${\bf E}({\bf r})=\lim_{\epsilon\rightarrow0^+}k\iiint_{D_{\epsilon}}\frac{\rho({\bf r'})}{|{\bf r}-{\bf r'}|^2}\hat{\bf R}d^3{\bf r'}$$ where $D_\epsilon$ is the space minus a ball with radius $\epsilon$ centered at ${\bf r}$.
It can be shown that if $\rho({\bf r})$ is finite or does not go to infinity $\textit{too fast}$, then the limit exists.
If you accept that, then the physics question one should ask is whether this gives the correct answer in physics.
In classical EM, the $\textit{macroscopic}$ field ${\bf E}$ is in fact the average of the $\textit{microscopic}$ field ${\bf e}$. (Landau and Lifshitz, $\textit{Electrodynamics of Continuous Media}$, p.1.)
So you can consider ${\bf E}({\bf r})$ as the average of ${\bf e}$ over a ball with radius $\epsilon$ centered at ${\bf r}$.
Now, it can be argue that $${\bf E}({\bf r})=k\iiint_{D_{\epsilon}}\frac{\rho({\bf r'})}{|{\bf r}-{\bf r'}|^2}\hat{\bf R}d^3{\bf r'}$$ as follows.
It can be shown that (1) the average field over the ball due to charges outside the ball is the same as the total field due to all charges outside the ball at the center of the ball. , and (2) the average field over the ball due to charges inside the ball is $$-k\frac{{\bf p}}{\epsilon^3}$$ where ${\bf p}$ is the total dipole moment inside the ball. (Griffith, $\textit{Introduction to Electrodynamics}$, p. 156-157, problem 3.41).
So when $\epsilon$ is small macroscopically, ${\bf p}\rightarrow{\bf 0}$.
velut luna
  • 4,064
You seem to be confused about the concept of the limit, which is normally covered in calculus courses. If you have, not a point charge, but a volume of charge with some density $\rho$, then the charge enclosed in a small sphere with radius $r$ is $$ dq = \rho\, dV = \rho \cdot \frac{4\pi}3 r^3 $$ and the electric field at the surface of the sphere will be proportional to $$ E \propto \frac{dq}{r^2} \propto \frac{\rho r^3}{r^2} = \rho r. $$ This field magnitude is well-behaved in the limit that $r$ is very small.
The zero-size point charge, zero-thickness surface charge, etc. are useful approximations when the size of the charge distribution is much smaller than the size of the field distribution that you care about. Physical point charges, surface charges, and line charges are all actually distributed over a finite volume. Even the charge of a single electron is distributed over a finite volume, thanks to quantum-mechanical uncertainty in the electron's position.
rob
  • 96,301
Your thinking is correct. At least, if the sphere is made up of small point charges, then the field will be infinite as you approach them.
There is a point you are missing when you say that this contradicts Gauss' law: Gauss' law only gives you the flux of the field. To get the field of the sphere from it in the textbook-way, you have to use symmetry. You argue then, that since a sphere is symmetric, the flux is simply field times area. But this is not true with your assumptions. A sphere consisting of discrete points is no sphere, it has at least no spherical symmetry. The contradiction is gone.
If we say, that the field equals a certain value, we mean the mean value. In your reasoning you are aiming exactly at a point charge. Then the field is infinite. But if you have points, you must also have gaps between them, and in those gaps the field is less than that which you get with the usual formula. If you say, that the points are dense (in the sense in which rational numbers are: between any two there is still one more), then they are infinitely many and have the charge of zero each.
You argue, that a value divided by zero is infinite ... but zero divided by zero is not! It can be, but it doesn't have to. And in this case you have the same zero-ness, if you divide them you get something finite.
In reality the electrons have a non-zero charge of course. But there are also finitely many of them. So there are real finite gaps.
But you are right - point charges are a strange thing. They are not consistent with classical electromagnetism. One could argue, that it's no problem that the potential gets infinite - just don't go there, than it's finite, one could say. But in the classical theory there is the concept of energy density of the field. And the energy of a point charge is infinite, if you do the calculation.
Well, this, too, would be no problem - as long as the number of charges is conserved, at least. But it isn't ... But the only thing that it proves is, that the world is not classical.
Anubhav Goel
  • 2,130
Ilja
  • 2,553
I had exactly your doubt. I hope you have found a clear response in this years. If you have not, try to see here: Electric field and potential exactly on the surface of a spherical conductor
Basically, what happens in a fraction when the numerator and denominator are practically both equal to zero (or "tend" to zero)?
You have to consider also the numerator going to zero when distance goes to zero in this case: using your words
we have assumed the small element of charge dq on which point P lies to be a point charge
you have to think that the small element on which point P lies is a point charge, but... does a point charge have a dimension? NO! So also $\mathrm dA$ has got dimension zero. We have to consider another method, beacuse this one based on point charges doesn't work for continous distributions of charges (when electrostatics began to be studied in the past, mathematicians and physicists did not know the existence of atoms and electrons).
