I have the propagator for the harmonic oscillator.
$$K(x_f,x_0,t)=\sqrt{\frac{m\omega}{2 \pi \hbar \sin{wt}}}\exp\left(\frac{i}{\hbar}\frac{m\omega}{2 \sin{\omega t}}((x_0^2+x_f^2)\cos\omega t-2x_0x_f)-\frac{i\pi}{4} \right)$$
and
$$K(x_f,x_0,t)=<x_f |e^{-\frac{i}{\hbar}\hat{H}t} |x_0 > $$
and the Schrodinger equation
$$\hat{H}\psi(\textbf{q},t)=i\hbar \frac{\partial}{\partial t}\psi(\textbf{q},t) $$
This may seem silly but I just cannot see from my notes how you can the propagator satisfies this Schrodinger equation. I think it may come from some lack of understanding as to what the propagator means.
Trajan
  • 895
The propagator does satisfy the Schrodinger equation for most values of x and t...
The easiest way to show this is to let $\hbar=m=\omega=1$. Also, we can work with $\sqrt{2\pi}e^{i\pi/4}K\to K$ instead of $K$ to clean up the mess a little further. Further, let $x_f\to x$ and $x_0 \to 0$.
Then let: $K=fe^{ig}$ with
$f=\frac{1}{\sqrt{\sin(t)}}$
and
$g=\frac{x^2\cos(t)}{2\sin{t}}$
And, since $m=\omega=1$, we want to show that:
$i\dot K = -\frac{1}{2}K''+\frac{x^2}{2}K$
Okay...
$\dot K=\frac{K}{2}\left({\frac{-\cos(t)}{\sin(t)}-i\frac{x^2}{\sin^2(t)}}\right)$
And...
$K''=K\left({i\frac{\cos}{\sin}-x^2\frac{\cos^2}{\sin^2}}\right)$
And... I'll leave the rest up to you. But, I assure you, you will find that: $HK=i\dot K$
...of course, this is not actually, true since actually: $HK=i\dot K+i\delta(x_f-x_0)\delta(t)$
And... I'll leave it up to you to reconcile this issue...
hft
  • 27,235
