What are the virtual particle pairs generated during the Hawking radiation? If a photon is emitted by Hawking radiation, what is its negative energy partner which fell into the black hole? Does it have a name? What is a negative energy photon anyway? Antiphoton? When a negative energy photon annihilate with a positive energy photon, can we see anything? Or just nothing since it just goes back to the vacuum? Thanks!
To start with, a photon is an antiparticle to a photon. There is no conservation of photons and certainly no negative energy photons.
Any body in space with a temperature larger than the "bath" it is in, i.e. the temperature of cosmic background radiation, will be radiating a black body radiation. The theoretical treatment is a combination of thermodynamics with field theoretical assumptions at the micrpscopic level, and that is the exposition in the wiki article..
The creation and annihilation of particles at the horizon is invoked to explain how particles can escape the gravitational attraction of the black hole at the microscopic level. As photons are antiparticles of photons and can be generated by in falling electrons for example, the only balances needed are directional and energy balances, so that the photon (or another particle) will not be trapped and fall back in.
In the case of the black body radiation of an ordinary body the temperature is such that the escaping radiation is a low energy photon, created by some transitions within the body and escaping from the surface. The energy balance is with the internal energy of the body, which cools incrementally. In the case of the black hole the energy balance is with its gravitational energy .
Here is a Feynman type diagram for the generation of particle/antiparticle by the Hawking radiation
hawking radiation
To calculate the probabilities quantum mechanically would take exact diagrams. These pairs are virtual and they can also have photon vertices , which will have a probability of escaping the horizon and form a real photon spectrum from the black hole. For example:
feynman diagram
anna v
  • 236,935
Hawking radiation suggests that quantum fluctuations occur near the event horizon of a black hole, resulting in the formation of virtual particle-antiparticles. One of them, a positron (a positively charged particle), can fly off into space, and the other particle, an electron (negatively charged), falls into the black hole and adds its negative energy to the mass of the hole.
Thus, in a pair of virtual particles created by Hawking radiation, one of them leaves the black hole with positive energy, and the other is “absorbed” by the hole with negative energy. A particle with negative energy is called an antiparticle because its energy is opposite to the energy of “ordinary” particles.
A photon with negative energy is actually an antiphoton, that is, the antiparticle of the photon. When a negative energy photon annihilates a positive energy photon, they can simply "disappear" and return to the vacuum without leaving a trace.
Let's imagine a situation where we find a roughly estimated parameter of some black hole that allows us to write down quantum mechanics with an accuracy sufficient to obtain an important possible amount of Hawking radiation. We acquire this hole in the topology of a level sphere with a radius of 10^-13 cm with deviations in order to modify it to improve the general properties of the latter. Let's make this hole the smallest. During the onset of vacuum fluctuations, we will see the creation of a pair of virtual particles, a positron and an electron. We need quantum mechanics of the electric field to analyze the consequences of the annihilation of photons created by this pair. There are many possibilities here, but the main thing that should be analyzed is the creation of electron-positron pairs that form quark-antiquark systems. Such systems are called framemanions. Unlike loop diagrams in Strullu, the formation of an infrared you symmetrical high energy relativistic theory is included. The first diagram adds formal UARTQG development, turning off the shell of the whale model of the universe, excluding the electrodin Ti incontinence of the new ones. Quark systems create a formal infrared thedon soufflé that forms a strict set of 1-2-3-4-5-6-7.
Astro
