What is the imparted angular momentum to a rigid body if the impulse force is offset by a distance $h$ from the center of mass and the imparted momentum from the center of mass is $mv$?
For a homogeneous sphere I said the imparted angular momentum is $L=mvh$, but I am not sure if that is correct.
John Alexiou
  • 40,139
In general if the imparted momentum vector $\vec{J}$ goes through a point $\vec{r}$ relative to the center of mass then the change in speed of the center of mass is
$$ \begin{aligned} \Delta \vec{v} &= \frac{1}{m} \vec{J} \\ \Delta \vec{\omega} & = I^{-1} (\vec{r} \times \vec{J}) \end{aligned} $$
where $\times$ is the vector cross product. In 2D if the impact momentum is $J$ at a distance $h$ from the center of mass, then angular momentum is $\vec{r} \times \vec{J} = (0,0,J h)$
The change in speed of the point of impact A is thus
$$ \begin{aligned} \Delta \vec{v}_A &= \Delta \vec{v} -\vec{r} \times \Delta \vec{\omega} \\ & = \frac{1}{m}\vec{J} - \vec{r} \times I^{-1} (\vec{r} \times \vec{J}) \end{aligned}$$
Making this into a 2D problem with $\vec{v}_A =(0,v_{impact},0)$, $\vec{J}=(0,J,0)$ and $\vec{r}=(h,0,0)$ you have
$$ \left. v_{impact} = \frac{J}{m} + \frac{J h^2}{I} \right\} J = \frac{1}{\frac{1}{m}+ \frac{h^2}{I}} v_{impact} $$
So the reduced mass of the system is $J=m_{reduced} v_{impact}$ with $m_{reduced} = \frac{1}{\frac{1}{m}+ \frac{h^2}{I}} $
A lot of insight comes from transforming the problem from a rigid body impact to a equivalent particle impact with reduced mass.
John Alexiou
  • 40,139
When you have an impulse $F\Delta t$ (I prefer that notation over $m\Delta v$ because it allows impulse to be imparted without worrying about the mass of the thing giving the impulse), then
  1. The momentum of the center of mass changes as though the impulse was applied there, so $$m\Delta v = F\Delta t$$
  2. The angular momentum changes according to the torque imparted $$\Delta \vec{L} = \vec{F}\Delta t \times \vec{h} $$
So yes, you got it right.
Floris
  • 119,981
