35
Is gravitational time dilation caused by gravity, or is it an effect of the inertial force caused by gravity?
Is gravitational time dilation fundamentally different from time dilation due to acceleration, are they the same but examples of different configurations?
Could you recreate the same kind of time dilation without gravity using centrifugal force?
bobie
  • 5,862
Jay
  • 673
6 Answers6
61
No, gravitational time dilation is no different to other forms of time dilation. They all stem from the invariance of the line element.
If we choose some coordinates, $x^i$, then the line element is given by:
$$ ds^2 = g_{ab}dx^adx^b \tag{1} $$
where the matrix $g_{ab}$ is called the metric tensor. In both GR and SR the line element is an invariant, that is all observers in all coordinate systems will calculate the same value for $ds$.
Suppose I'm using some set of coordinates $(t, x, y, z)$ to calculate your line element using equation (1). We'll stick to SR for now, where $g$ is just the Minkowski metric, so I get (I'm pulling the usual trick of setting $c = 1$):
$$ ds^2 = -dt^2 + dx^2 + dy^2 + dz^2 $$
Now suppose you're doing the same calculation in your rest frame coordinates $(t', x', y', z')$. By definition, in your rest frame $dx' = dy' = dz' = 0$, so you would calculate:
$$ ds^2 = -dt'^2 \tag{2} $$
Since we must both agree on the value of $ds^2$ we can equate the right hand sides of equations (1) and (2) to get:
$$ -dt^2 + dx^2 + dy^2 + dz^2 = -dt'^2 $$
If any of $dx$, $dy$ or $dz$ are non-zero, i.e. if you're moving in any way in my coordinate system this means that:
$$ dt \ne dt' $$
and therefore our measurements of elapsed time will not match. This is why we get time dilation. In introductory works on SR you'll see time dilation calculated using various arrangements of light beams and mirrors, but this is the fundamental reason it occurs.
I've used the example of SR above because the metric tensor is diagonal and all the elements are $-1$ or $1$, so it's easy to write out the expression for $ds^2$. In GR the metric may not be diagonal (it's often possible to choose coordinates where it is) and the values of the elements in the metric will typically be functions of position. However the working is exactly the same. We'd end up concluding that $dt \ne dt'$ in exactly the same way.
Since you specifically asked about time dilation and centrifugal force, let's do the calculation explicitly. Suppose you're whirling about a pivot with velocity $v$ at a radius $r$ and I'm watching you from the pivot. I'm going to measure your position using polar coordinates $(t, r, \theta,\phi)$, and in polar coordinates the line interval is given by (I'm leaving $c$ in the equation this time):
$$ ds^2 = -c^2dt^2 + dr^2 + r^2(d\theta^2 + \sin^2\theta d\phi^2) $$
Note that this is just the flat space, i.e. Minkowski metric, in polar coordinates. We're using the flat space metric because there are no masses around to curve spacetime (we'll assume you and I have been on a diet :-). We can choose our axes so you are rotating in the plane $\theta = \pi/2$, and you're moving at constant radius so both $dr$ and $d\theta$ are zero. The metric simplifies to:
$$ ds^2 = -c^2dt^2 + r^2d\phi^2 $$
We can simplify this further because in my frame you're moving at velocity $v$ so $d\phi$ is given by:
$$ d\phi= \frac{v}{r} dt $$
and therefore:
$$ ds^2 = -c^2dt^2 + v^2dt^2 = (v^2 - c^2)dt^2 $$
In your frame you're at rest, so $ds^2 = -c^2dt'^2$, and equating this to my value for $ds^2$ gives:
$$ -c^2dt'^2 = (v^2 - c^2)dt^2 $$
or:
$$ dt'^2 = (1 - \frac{v^2}{c^2})dt^2 $$
or:
$$ dt' = dt \sqrt{1 - \tfrac{v^2}{c^2}} = \frac{dt}{\gamma} $$
which you should immediately recognise as the usual expression for time dilation in SR. Note that the centripetal force/acceleration does not appear in this expression. The time dilation is just due to our relative velocities and not to your acceleration towards the pivot.
Finally, since I did say there was no difference between gravitational and other forms of time dilation I should justify this by proving that the special relativity calculation above works in the same way for combined gravitational and speed related time dilation. Specifically we'll calculate the time dilation for an object in orbit around a black hole. This turns out to be straightforward, showing how powerful this technique is. All we need to know is that the metric for a black hole is:
$$ ds^2 = -\left(1-\frac{2GM}{c^2r}\right)c^2dt^2 + \frac{dr^2}{1-\frac{2GM}{c^2r}}+r^2d\theta^2 + r^2\sin^2\theta d\phi^2 $$
We proceed as before setting $dr = d\theta = 0$ and $\theta = \pi/2$ to get:
$$ ds^2 = -\left(1-\frac{2GM}{c^2r}\right)c^2dt^2 + r^2 d\phi^2 $$
The orbital velocity is:
$$ v = \sqrt{\frac{GM}{r}} $$
and as before we can rewrite $d\phi$ as:
$$ d\phi = \frac{v}{r}dt = \frac{\sqrt{GM/r}}{r} dt $$
and substituting this in our metric gives:
$$ ds^2 = -\left(1-\frac{2GM}{c^2r}\right)c^2dt^2 + \frac{GM}{r}dt^2 $$
As before, in the rest frame of the orbiting body we have $ds^2 = -c^2dt'^2$, and equating this to the above value for $ds^2$ gives:
$$ -c^2dt'^2 = -\left(1-\frac{2GM}{c^2r}\right)c^2dt^2 + \frac{GM}{r}dt^2 $$
which simplifies to:
$$ dt' = \sqrt{1-\frac{3GM}{c^2r}}dt = \sqrt{1-\frac{3r_s}{2r}}dt $$
where $r_s$ is the Schwarzschild radius: $r_s = 2GM/c^2$.
And, reassuringly, this is exactly the result Wikipedia gives for the time dilation of an object in a circular orbit.
This is the point I want you to take away. Once you understand the basic principle that the line element is an invariant you can use this to calculate the time dilation for any object, whether in a gravitational field or not, and whether moving or not. In fact, as I've just demonstrated, understanding this basic principle opens the door to understanding general relativity as well as special relativity. That's how important it is!
John Rennie
  • 367,598
Sure, circular observers observe time dilation. Consider the worldline of a circular observer in flat spacetime. We know, right off hand, relative to a "stationary" observer, that the spatial coordinates of such an observer will be
$$\begin{align} x&= r\cos\left(\omega\,\tau\right)\\ y&= r\sin\left(\omega\,\tau\right) \end{align}$$
for some parameter $\tau$. Let's just call it the proper time.
Then, remembering that $-1 = -{\dot t}^{2} + {\dot x}^{2} +{\dot y}^{2} + {\dot z}^{2}$, for this path, we have:
$$\begin{align} -1 &= -{\dot t}^{2} + r^{2}\omega^{2}\sin^{2}\left(\omega\,\tau\right) + r^{2}\omega^{2}\cos^{2}\left(\omega\,\tau\right)\\ 1&= {\dot t}^{2} - r^{2}\omega^{2}\\ \dot t &= \sqrt{1 + r^{2}\omega^{2}}\\ t &= \tau\sqrt{1 + r^{2}\omega^{2}} \end{align}$$
Compare this to the GR formula for gravitational time dialation (at a stationary point) $t = \tau/\sqrt{1-\frac{2GM}{rc^{2}}}$
Thus, if you are orbiting in a circle at radius $R$ in empty space, you have the equivalent time dilation to being held stationary at a radius $r$ from a gravitational body of mass $M$ if you are rotating with angular speed:
$$\begin{align} 1 + R^{2}\omega^{2} &= \frac{rc^{2}}{rc^{2} - 2GM}\\ R^{2}\omega^{2} &= \frac{2GM}{rc^{2} - 2GM}\\ \omega &= \frac{1}{R}\sqrt{\frac{2GM}{rc^{2} - 2GM}} \end{align}$$
How "equivalent" this is is obviously subject to debate, since everything else would feel different. But you can certainly get the same time dilation kinetically.
Gravity is a inertial force where reference frame is Spacetime. So, Gravitational Time Dilation and Time Dilation due to accelerated frame are both same.
And yes, you can recreate same kind of Time Dilation using centrifugal force.
Well, the answer is "no" time dilation is always the same effect and is due to velocity! Indeed, when an object is located in a gravitational field it is falling. Even when you sit on your chair you are falling in the Earth's gravitational field, otherwise you would float in the air as in the ISS! Let's equate the factors for time dilation of special and of general relativity, where $R_S$ is the Schwarzschild radius: \begin{equation} \Delta t'=\frac{\Delta t}{\sqrt{1-\frac{v^{2}}{c^{2}}}}=\frac{\Delta t}{\sqrt{1-\frac{R_{S}}{r}}}\label{eq:time dilation compared-1-1} \end{equation} hence $\frac{v^{2}}{c^{2}}=\frac{R_{S}}{r}\Longrightarrow v^{2}=\frac{2GM}{r}\label{eq:time dilation compared-2-1}$ and $v=\sqrt{2rg}=\sqrt{2V}$, where $V$ is the gravitational potential. We therefore put in evidence the relationship that links velocity and gravity in relativistic time dilation (both in SR and GR): \begin{equation} v=\sqrt{2V} \end{equation} Thinking of time dilation as always due to velocity also explains why in artificial gravity (e.g. in a hypothetical vertically accelerating space elevator) we would experience both the sensation of natural gravity "and" time dilation, though no natural gravity is present.
If you love gravity and relativity, I would add that curved spacetime produces quantitatively exact results but "qualitatively" (I think) it is a wrong concept. There is no curved spacetime but a fluid quantum vacuum. The relativistic effects are the same: https://hal.archives-ouvertes.fr/hal-01423134v6
mfc
  • 163
Gravitational time dilation is primarily caused by gravity itself, rather than by the inertial force caused by gravity. It is a consequence of the curvature of spacetime in the presence of mass or energy. In general relativity, gravity is not viewed as a force in the traditional sense, but rather as a result of the curvature of spacetime caused by massive objects. When an object with mass or energy is present, it curves the fabric of spacetime around it, affecting the motion of other objects nearby. Gravitational time dilation occurs because the curvature of spacetime near a massive object affects the flow of time. Time flows slower in regions of stronger gravitational field, meaning clocks near massive bodies will tick slower compared to clocks located further away. This effect has been observed in experiments and has important implications for our understanding of space, time, and the behavior of clocks in gravitational fields. As for the relationship between gravitational time dilation and time dilation due to acceleration, they are conceptually similar effects, but they arise from different causes. Gravitational time dilation is related to the curvature of spacetime caused by mass and energy, while time dilation due to acceleration (known as "kinematic time dilation") arises from the effects of relative motion and the constant speed of light. Regarding your question about recreating time dilation without gravity using centrifugal force, the answer is yes. The time dilation caused by centrifugal force is conceptually similar to the effects of gravity. When an object undergoes circular motion, it experiences an outward centrifugal force due to its acceleration towards the center of rotation. This acceleration leads to time dilation, meaning clocks moving at different speeds within the same system will experience different rates of time. However, it's important to note that the centrifugal force is not the exact equivalent of gravity. The equivalence principle in general relativity states that the effects of gravity are locally indistinguishable from the effects of acceleration. So, while centrifugal force can cause time dilation similar to gravity, it's not a direct substitute for gravitational time dilation in all cases. Gravitational time dilation arises from the profound insights of general relativity, Albert Einstein's theory of gravity. In this innovative framework, gravity is understood not as a force acting between objects but as the curvature of spacetime caused by mass and energy. Massive objects, such as planets, stars, or black holes, distort the fabric of spacetime, leading to the phenomenon of time dilation. The concept of time dilation itself is rooted in the fundamental principles of relativity. According to special relativity, the passage of time is not absolute but depends on the relative motion between observers. Moving clocks appear to tick slower for an observer in a different reference frame. However, gravitational time dilation goes beyond special relativity by considering the effects of gravity on the flow of time. As an object approaches a massive body, it encounters a stronger gravitational field, resulting in a slowing down of time. This means that clocks in a stronger gravitational field run slower compared to clocks located in weaker fields. A notable example is the time dilation experienced near a black hole: an observer falling into a black hole would perceive time passing more slowly relative to an external observer far away from the black hole. Gravitational time dilation has been experimentally confirmed through various tests. For instance, precise atomic clocks on Earth have been used to measure the small discrepancy in time compared to clocks aboard satellites in orbit. These experiments validate the predictions of general relativity, confirming that gravity indeed affects the passage of time. Now, coming back to your question about the relationship between gravitational time dilation and time dilation due to acceleration, they share similarities but arise from different causes. Gravitational time dilation emerges from the curvature of spacetime caused by mass or energy, while time dilation due to acceleration stems from the effects of relative motion and the constant speed of light. Acceleration-induced time dilation, also known as kinematic time dilation, occurs when an object undergoes acceleration and experiences a change in velocity. According to special relativity, the closer an object approaches the speed of light, the slower time flows for it relative to a stationary observer. This effect has been observed in high-speed particle accelerators and is a critical factor to consider in space travel scenarios where significant velocities are involved. Regarding the possibility of recreating time dilation without gravity using centrifugal force, the answer is affirmative. When an object rotates or undergoes circular motion, it experiences an outward-pushing centrifugal force due to its acceleration toward the center of rotation. This acceleration can lead to time dilation, as clocks moving at different speeds within the rotating system will exhibit different rates of time flow. However, it is important to note that the centrifugal force is not precisely equivalent to gravity. While they can induce similar effects, such as time dilation, gravity's nature as the curvature of spacetime is more fundamental and encompasses a broader range of phenomena. The equivalence principle in general relativity states that effects caused by gravity and effects caused by acceleration are locally indistinguishable. Therefore, the phenomena of gravitational time dilation and centrifugal force-induced time dilation share conceptual similarities but are not entirely interchangeable in all circumstances.
-6
Interesting thread, imagine the following test concerning time dilation.
  1. Two synchronized atomic clocks, one on earth, the other one in a vehicle going to the moon with astronauts. The astronauts report their clock status to earth.
  2. Four measuring points, comparing the clocks:
    A. Before the trip starts (showing the same time)
    B. After the full acceleration, starting cruising in space to the moon.
    C. Before launching the brakes (before decelerating) when coming close to the moon.
    D. After landing on the moon.
I am 99,9% convinced that at point B there will be a significant time difference between the clocks. Between point B and C basically nothing happens (no time dilation). After point D, another significant time difference has occured.
In other words, I would eat my hat if time dilation is not always caused by a force (acceleration, deceleration, being close to massive matter) acting on matter, and never can happen when just cruising in "empty" space. Muons, yes, they live longer because of the deceleration caused by the friction in the earth atmosphere (which has the same time dilation effect as acceleration).
The spacetime concept works as a purely mathematical framework, but is like focusing on a shadow in a room with a physical moving object.
Time dilation is a physical phenomenon which involves a force field that slows down the particles of a system. When particles interactions take place with lower frequency, time is effectively slowed down. The mechanics of this is unknown. Time emerges from this effect, it is not "floating around" in space as a dimension.
