11
A load dump occurs when the load to which a generator is delivering current is abruptly disconnected. In automotive electronics, this applies to disconnecting a battery while it is being charged by the alternator. It is apparently well-described in this $65 SAE document; Wikipedia claims it can be "as high as 120 V and may take up to 400 ms to decay". This document claims a 12V system dump can be as high as 87V and 400ms long:
       12V system      24V system
Us     65V to 87V      123V to 174V     // maximum voltage
Ri     0.5Ω to 4Ω      1Ω to 8Ω         // source resistance
td     40ms to 400ms   100ms to 350ms   // pulse length
tr     10ms??          5ms??            // rise time
The last linked document also has a table listing TVS (Transient Voltage Suppressor) energy absorption, as follows:
Table 2 - Energy [J] absorbed (Vclamp=45V)
td [ms]   source resistance [Ω]
     0.5    1     1.5   2     2.5   3     3.5   4
 50  18.57  9.62  6.26  4.50  3.41  2.68  2.17  1.80
100  37.15  19.23 12.51 8.99  6.83  5.36  4.34  3.59
150  55.72  28.85 18.77 13.49 10.24 8.04  6.51  5.39
200  74.30  38.46 25.02 17.98 13.65 10.72 8.68  7.18
250  92.87  48.08 31.28 22.48 17.07 13.40 10.85 8.98
300  111.44 57.69 37.53 26.98 20.48 16.08 13.02 10.77
350  130.02 67.31 43.79 31.47 23.89 18.76 15.19 12.57
400  148.59 76.92 50.05 35.97 27.31 21.44 17.37 14.3
Now, I want to clamp much lower than 45V (say 20V), and would like to recalculate these values. The author writes:
  • Calculated using the method given in Annex E.1.1.(e) where Ri=RL (for maximum power transfer).
This reveals the formula:
We = (Us)2 x td / Ri / 4.6
... And updates the table as follows:
Energy [J] absorbed (Vclamp=20V)
 50  97.59  48.79  32.53  24.40  19.52  16.26  13.94  12.20
100  195.17 97.59  65.06  48.79  39.03  32.53  27.88  24.40
150  292.76 146.38 97.59  73.19  58.55  48.79  41.82  36.60
200  390.35 195.17 130.12 97.59  78.07  65.06  55.76  48.79
250  487.93 243.97 162.64 121.98 97.59  81.32  69.70  60.99
300  585.52 292.76 195.17 146.38 117.10 97.59  83.65  73.19
350  683.11 341.55 227.70 170.78 136.62 113.85 97.59  85.39
400  780.70 390.35 260.23 195.17 156.14 130.12 111.53 97.59
This gives a maximum value of 781J. Did I do this correctly? My TVS system must absorb up to ~800J, passing nearly 30A? It seems like a heck of a lot, though it will be for up to 6 parallel semi truck batteries (~100AH each) in addition to its 130A+ alternator. (Could the source resistance be even lower than 0.5Ω?) What combination of TVS elements can effectively pass 800J without violating its clamping voltage by much, and what makes it more effective than other solutions?
I am protecting low-voltage digital and analog circuitry, which also have their own power filtering.
Volker Siegel
  • 1,076
  • 26
tyblu
  • 8,207
  • 41
  • 70
I can't speak to SAE J1113, but for SAE J1455 (12-V heavy truck, where the loads should be larger) the load dump is defined as a 100 V peak with about ~0.6 s fall time and ~0.6 Ω impedance, which is a pain to live through.
The two broad methods to survive are either
  • Disconnect yourself and let it pass:
Which is usually preferable and cheaper. Load dumps are in a class of faults that many devices are not expected to operate during (unlike coupled inductive transients), so unless you're some critical device (ABS, ECU), you're allowed to shut down and reset when you see a load dump.
Very broadly speaking, to do this you could have a Zener diode on your input, where once it breaks down and starts conducting, switches some pass transistor to disconnect yourself entirely. Obviously your pass transistor will have some voltage rating, so selecting a TVS is still needed (see following), but it won't have to clamp anywhere near as much voltage, energy, and power.
  • clamp the whole thing.
This is also quite possible with TVS as you mention, and then it really depends on how hard you want to clamp it. If you're fine with 75 V coming through, I think I've seen 500 W SMC's used. If you want it like almost nothing ever happened, you can do as I've seen and use (2) 5 kW 5KP22CA TVS in parallel. They alone can clamp the entire load dump themselves; I've tested a pair that survived (5) 100 V dumps in a row, about 10 seconds apart between each.
The math behind it is somewhat hazy to me, as the figures provided on the datasheets don't seem as though they were meant for transients any slower than 60 Hz. The 5 KW rating is for a 1 ms pulse, which is obviously just 5 J.
The peak energy it dissipates will be (100 V - 24 V)/0.4 ohms * 24 V = 4560 W, but this will decay roughly exponentially to nothing with a tc of about 300 msec. If we just call that a triangle (very conservative), it's 0.5 * 4560 W * 0.3 s = 684 J. If we extrapolate the Figure 1 rating curve on the 5KP datasheet, it suggests that a 100 ms pulse can have a maximum power rating 1000 W, or total energy of 100 J, and even more energy if we smear it out further, so we're in the ball park with 2 of them in parallel and tests seem to bore it out.
Littelfuse 5KP-series TVS datasheet, Figure 1
If you wanted something better, I'd come up with an equation for the curve and give it an asymptote at the maximum steady-state dissipation (8 W...though that might not make a difference), then do some integration with that over your pulse to see how much of the rating you use up :P
Nick T
  • 12,480
  • 45
  • 72
  • UPD: A special SLD series (introduced in 2015) might be even better than 5KP, they are automotive, rated 2.2 kW for 10/150 ms load dump pulse. – Cubrilo Aug 01 '18 at 06:21
Here is how you can protect against an automotive load dump
LT4356 "Surge stopper" data sheet
They say
The LT®4356 surge stopper protects loads from high voltage transients. It regulates the output during an overvoltage event, such as load dump in automobiles, by controlling the gate of an external N-channel MOSFET. The output is limited to a safe value thereby allowing the loads to continue functioning. The LT4356 also monitors the voltage drop between the VCC and SNS pins to protect against overcurrent faults. An internal amplifier limits the current sense voltage to 50mV. In either fault condition, a timer is started inversely proportional to MOSFET stress. If the timer expires, the FLT pin pulls low to warn of an impending power down. If the condition persists, the MOSFET is turned off. After a cool down period, the GATE pin pulls up turning on the MOSFET again.
https://www.analog.com/en/products/lt4356-1.html
Russell McMahon
  • 150,303
  • 18
  • 213
  • 391
BullBoyShoes
  • 928
  • How have you used this before, and why did you chose it instead of others? – tyblu Jan 09 '11 at 20:15
  • In a 12v automotive system, incidentally a system that passed all UK EMC requirements for fitment in emergency vehicles. – BullBoyShoes Jan 09 '11 at 20:16
    The link is no longer valid (you should have written the part number). However, I think the component was the Linear Technology LT4356 "surge stopper". – MV. Nov 15 '15 at 06:22
  • yes, please edit your answer to mention the part you’re specifying, because that link isn’t correct. if you are referencing the LT4356 (or similar) then you’ll get my upvote. – Anthony May Sep 16 '18 at 16:59
