In the link below, this circuit I found is what I needed. Only the length of the pulse and the delay are not what I want.
When I want just 0.5sec before pin 3 is up and the pulse duration I want is also 0.5sec, can someone tell me how big my resistors and capacitors must be? Or can someone tell me how I can calculate this?
My source power is 16 Volts I have already found 555 timers that can operate with 16 Volts, so thats not the problem.
When someone has another idea with two 555-timers, or something else that does the same, it's also OK.
Thanks
Circuit I need with wrong delays
Jorn
Assuming you're talking about akhmed's circuit:
The width of the output pulse is calculated in the normal way:
$$T_{ON} = 1.1\cdot R4 \cdot C4$$
The initial trigger delay uses the same formula:
$$T_{DELAY} = 1.1\cdot R1 \cdot C1$$
For both of these, you might use 470 kΩ and 1 µF, giving a nominal value of 0.517 seconds for each.
The only "trick" required is that R3+C3 (via D2) must pull the trigger voltage above 1/3 VCC sometime after \$T_{DELAY}\$ but before \$T_{DELAY} + T_{ON}\$ (i.e., between 0.6 and 0.9 seconds). You need to keep the ratio of R3:R1 at around 1:3, and adjust C3 to get roughly the delay you need.
This is complicated by the forward drop of D2, but an approximation would be
$$T = -ln(1/3)\cdot R3 \cdot C3 = 0.4 \cdot R3 \cdot C3$$
If you set R3 to 150 kΩ and T to 0.75 s, you can solve for C3, giving 12.5 µF. This isn't a standard value, but 12 µF is, which should be close enough. Some experimentation may be required.
Dave Tweed
  • 172,781
  • 17
  • 234
  • 402
  • If you think the answer is valuable, you should vote it up. – Dave Tweed Jan 05 '19 at 21:26
  • I will test it. If I would still have questions, I will ask them. When it works, I'll let it know. Now I am in the exams, so I don't have many time. But when I have tested it, you will hear me. – Jorn Jan 05 '19 at 21:30
  • Sure, I will vote up if I can. But my reputation is to low. I'm new. Excuse me – Jorn Jan 05 '19 at 21:49
