For calculating the equivalent noise bandwidth of a non-brickwall filter, I can find two different sets of numbers, both of which claim they are similar things:
Order   EqNBW
1   1.5708
2   1.1107
3   1.0472
4   1.0262
5   1.0166
6   1.0115
7   1.0084
8   1.0065
9   1.0051
10  1.0041
1 1.57
2 1.22
3 1.16
4 1.13
5 1.12
Which is correct?
Or are they both correct; just used in different calculations?
Update
After figuring this out, I made a chart of the different factors and the types of filters they work for: ENBW Filter correction factors vs order
endolith
  • 28,734
  • 24
  • 119
  • 184
The effective noise bandwidth depends on the shape of transfer function. It's easy to calculate it numerically.
See my Matlab script below that calculates the ENBW for a Butterworth lowpass filter. You can adapt it to your needs.
for N=1:10
  [b,a] = butter(N, 1, 's');
  f = @(x) (abs(freqs(b,a,x)).^2);
  bw = integral(f, 0, 1e6);
  fprintf('Order: %d, ENBW: %g\n',N, bw);
end
In case you don't have Matlab, the output is given below
Order: 1, ENBW: 1.5708
Order: 2, ENBW: 1.11072
Order: 3, ENBW: 1.0472
Order: 4, ENBW: 1.02617
Order: 5, ENBW: 1.01664
Order: 6, ENBW: 1.01152
Order: 7, ENBW: 1.00844
Order: 8, ENBW: 1.00645
Order: 9, ENBW: 1.0051
Order: 10, ENBW: 1.00412
Mario
  • 8,195
  • 15
  • 20
  • Ohhhhhhhhhhhhhhh... The 1.11 number is for a 2nd-order Butterworth filter, and the 1.22 number is for 2× 1st-order filters in cascade? – endolith Jan 19 '17 at 17:16
    Yes, according to your reference (http://analog.intgckts.com/equivalent-noise-bandwidth/). – Mario Jan 19 '17 at 17:24
  • Mario, could you clear something up? Is the $\pi$/2 figure (order = 1) applied at the signal level (i.e. the voltage or current) or does it apply to the power thus making the factor to be applied to signals $\sqrt{\pi/2}$? I would appreciate your guidance. @carloc - this is the post I mentioned. – Andy aka Jan 20 '17 at 09:19
  • @Andyaka It's applied to your bandwidth. So to calculate the total noise of a resistor connected to a capacitor (first order RC LPF) you'd use $$\sqrt{ 4 k_\text{B} T R \left(\frac \pi 2 \Delta f \right) }$$ So if $f_c$ of the RC filter were 10 kHz, you'd pretend it's a brickwall filter at 15.7 kHz instead. – endolith Jan 20 '17 at 14:47
  • @endolith so is that 1.57 or sqrt(1.57) for noise voltage? – Andy aka Jan 20 '17 at 14:48
  • @Andyaka Total noise voltage would be multiplied by sqrt(1.57) – endolith Jan 20 '17 at 14:50
