For the circuit below, if the bottom terminal is -Vin and not grounded, is applying voltage divider possible at all?
If this is the case, what would the equation be? I never heard of a voltage divider with no reference ground at the bottom.
Xiagua
  • 486
  • 14
Yes. Consider a more general case and apply the superposition theorem:
schematic
$$ V_o = V_o(V1) + V_o(V2) = V1 \frac{R2}{R1+R2} + V2 \frac{R1}{R1+R2}$$
arielCo
  • 311
"Ground" is (usually) just a label we put on the point in a circuit that we want to call "Zero Volts" -it has no special magic properties.
A voltage divider will work whether or not one end of it is connected to "Ground". Vout is still proportional to the resistor values, but the total voltage is Vin-Vb (Vb = voltage at the bottom of R2), and will be shifted by the difference in voltage between Vb "ground".
Peter Bennett
  • 59,212
  • 49
  • 132
Sure. The analysis is really straightforward. Let's say you have Vin1 (the positive input) and Vin2 (the negative input). The derivation is as follows (with \$i\$ being the current flowing through R1,R2):
$$ i = \frac{V_{in1}-V_{in2}}{R_1 + R_2} \\ V_{OUT} = V_{in_2} + i R_2 = V_{in_1} - i R_1 $$
It's still a voltage divider, but the "lower end" isn't 0V anymore. Still has its uses, but not as common.
uint128_t
  • 8,724
  • 27
  • 28
