I have a topic to study regarding Energy Meters. In the Syllabus it says Energy Meter, in the textbook it says Induction Wattmeter and one online reference by IIT, says WattHour Meter/Induction Type Energy Meter.
Are all these things the same?
A wattmeter tells you the power being pumped into a target load. If the load consumes 100 watts the meter reads 100 watts. If power drops to zero watts the meter reads zero watts. Should the power be flowing in the opposite direction the wattmeter will read a negative value: -
Note that the meter will read zero in the centre of the scale should it be an analogue meter as depicted in the picture above. Here's where the picture came from.
An energy meter will totalize power over a given time period producing a reading in joules (watt seconds) or watt hours. It must also be able to differentiate negative values of power from positive amounts of power. It's basically formed by adding an integrator to the output of a wattmeter.
A first-step classification for you to initially navigate yourself and start lurking (learning) from:
By market:
By measuring principle:
By mesuring quantity:
