17
Without performing any update, suddenly today when I tried to power on a VM in VirtualBox, the host machine (running Ubuntu 16.04) freezed.
  • I tried couple of times and the problem keep repeating.
  • I run memtest: all good
  • Tried to create a new VM just in case: same issue.
  • Downgraded the VirtualBox installation: didn't help at all.
  • Disabled network, shared folders etc: Nothing.
On the same machine I've also got Windows 10 in dual boot. I've got couple of VMs there in VBox and VMWare. Just to minimize the probability of any HW issue, I started the VMs there and they work just fine.
Any idea?
The only way to recover the host was to hard-reset.
ps: The freeze happens as soon as I click the "Start" button.
Host details:
  • VirtualBox: Version 5.0.40_Ubuntu
  • Kernel: 4.13.0-26-generic
  • Guest: irrelevant (windows 10, OpenSuse, CentOS)
  • The log file of VirtualBox is empty.
Sanosay
  • 441
5 Answers5
16
Figured it out after following:
https://ubuntuforums.org/showthread.php?t=2382314
(Had to upgrade VBox to 5.2 and all worked ok)
In case you need it, had also to follow : VirtualBox - RTR3InitEx failed with rc=-1912 (rc=-1912) in order to completely uninstall all the previous installations
There was a silent security update that caused old VirtualBox installations (older than 5.2) to hang the entire host.
Sanosay
  • 441
I really appreciate Sanosay, and Bertrand Lo question and answers here. I followed them and fixed this issue on my situation, let me summarize what I've done for this issue step by step completely here for your convenience:
  1. sudo apt autoremove virtualbox
  2. Reboot.
  3. Add deb https://download.virtualbox.org/virtualbox/debian xenial contrib into Ubuntu 16.04's software source list.
    (by start "Software & Updates, and choose the "Other Software" tab, and click "Add" button, then paste the deb https://download.virtualbox.org/virtualbox/debian xenial contrib in the APT line)
  4. sudo apt update && sudo apt install virtualbox-5.2
    Be cautious! It's virtualbox-5.2 instead of virtualbox.
  5. after installation, reboot
  6. run virtualbox, and you'll find that your virtualbox version is 5.2 now, and it'll not cause whole host ubuntu16.04 crash when run one guest OS.
The original version virtualbox in ubuntu16.04 could not work correctly with Ubuntu16.04 latest patch, even Canonical claims 16.04 is their LTS (Long Term Support) version, at least it couldn't support the virtualbox 5.0 now.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Clock ZHONG
  • 1,015
  • 13
  • 17
also ran into this problem, thanks for the advices above! However, there's one more step that's missing for 'apt update' to work, new keys, paste this into Terminal:
wget -q https://www.virtualbox.org/download/oracle_vbox_2016.asc -O- | sudo apt-key add -
wget -q https://www.virtualbox.org/download/oracle_vbox.asc -O- | sudo apt-key add -
(from https://www.virtualbox.org/wiki/Linux_Downloads)
Exactly this situation. And totally uninstalled.
And add repository of official VB:
then reinstall. work as usual.
Today I found Ubuntu16.04 already include virtualbox-5.2 into its latest patch: https://download.virtualbox.org/virtualbox/debian xenial/contrib amd64 virtualbox-5.2 amd64 5.2.10-122088~Ubuntu~xenial
So it means we could just use:
sudo apt upgrade
to fix this issue directly. Maybe Canonical dedicated engineering&validation teams also found this issue and read our post here. Now the solution is much simpler. Just one line command:
sudo apt upgrade
Then reboot.
Clock ZHONG
  • 1,015
  • 13
  • 17
