60
I have two questions on ext4:
  1. Is there currently a way to mount an ext4 partition in Windows (XP/Vista/7) to get basic read support?
  2. If not, are there any plans to support this someday?
Jorge Castro
  • 73,717
htorque
  • 66,086
10 Answers10
34
There was a utility called ext2read to browse Ext partitions in Windows (including Ext4 partitions) which may not work anymore as mentioned in the comment below by @heynnema and could corrupt your partitions.
The project isn't updated since 2012
Chakra
  • 3,542
25
ext4 has some support through the older ext2* projects. btrfs has no current Windows support. New filesystems are always going to have a period where there's no support on another operating system and, frankly, that's going to suck.
It should also be mentioned that projects that try to read the filesystem into another system are always going to give you an increased risk of noshing up your partition.
So with that in mind, there is one solution that would take perhaps 30 minutes to an hour to set up that would give you near-native speed, any Linux partition support and would be just as safe (or very close to) as mounting it from Linux: Virtualise!
Yeah I'm suggesting you give up 300megs of RAM and a gig of disk space to run Ubuntu Server from within Windows. Most modern virtualisation systems like Virtualbox and VMWare allow you to pass the VM an entire disk or partition so that's what you'd do. Mount it from within virtual-ubuntu, install samba, share the ubuntu-mounted disks and mount the shares from within Windows.
It sounds like a lot of overhead but Ubuntu server is pretty slick and it won't need much in the way of resources. Once installed, you could probably get away with 150megs of RAM for it.
Oli
  • 299,380
13
If you're talking about a dual-boot system, Windows cannot natively read Linux-formated partitions. Therefore, you have two options.
Recommended solution - Shared storage
Create a NTFS partition that will hold the files that you wish to be accessible from both Windows and Ubuntu, and store your files there.
This is the recommended, safe solution.
Alternate solution - Third-party software
Software is available for Windows that allows you to read and write to Linux partitions, to some extent.
One example of such software is Ext2Fsd. Ext2Fsd has limited EXT4 support. By default, it will load the filesystems in read-only mode, but you can enable read-write mode if you really want to. This is, however, not recommended.
  • EXT4 partitions mounted using Ext2Fsd will be displayed as EXT3. This is normal.
Note that these features of the fourth extended filesystem are unsuported:
  • Journal: log-based operations, external journal
  • Extent: size truncating & expanding, file deletion
  • Extended Attributes: ACL support
  • Note: an error may be displayed after installing Ext2Fsd; the application still works.
After installation, restart your computer and open Ext2 Volume Manager from the Start menu.
This is where you assign or change the drive letters for your Linux partitions, mount and unmount them, or perform other operations.
If you want to enable write support for an EXT4 filesystem, select Ext2 Management, uncheck the Mount volume in readonly mode box and then click Apply.
You can also select if you want your Linux partition to be automatically mounted on startup (you shouldn't use this option for USB drives and removable media).
Note: this solution is far from perfect and data corruption may occur on your Linux partition. Use this at your own risk!
SirCharlo
  • 40,096
To read ext4 you can use Ext2Fsd. It's a driver for Windows. The name suggest that it only work with ext2 and the site say that it work with ext2 and ext3 but last versions support ext4 too.
An alternative is to install CoLinux on the windows machine and set it up with a minimal system (enough to mount the filesystem in question) and Samba. Then just mount your FS, and share it to windows. Not exactly elegant, but works nicely and doesn't risk filesystem corruption due to faulty drivers.
If a CoLinux install from scratch is too much hassle, try AndLinux, which is CoLinux with an OS already good to go out of the box. Installs in twenty minutes. You'll still need to set up the mounting, but the filesystem shares should already be good to go.
Perkins
  • 646
You can install Linux in a virtual machine then bind the physical drives or partitions directly to it. Then set up the machine to be accessible over Samba/CIFS and map the shares to drive letters in Windows Explorer.
There is a guide for doing this in VirtualBox.
That's probably the simplest way and should work transparently after setup correctly. It should work with any filesystem that Linux supports and not have to much around with horribly out of date (and possibly unstable) 3rd party utils.
With some work you might even be able to make your entire main Linux distro bootable from within Windows.
You can use ex2explore for accessing ubuntu file from windows
Tachyons
  • 17,455
You could try booting into an Ubuntu live CD and mounting your existing Ubuntu partition from there, but if it crashed badly enough I don't know if this would work.
Shawn
  • 1,478
You need to install Samba into Ubuntu and set up a shere folder in the Ubuntu partition. You can then map to that network resource from windows.
sbtech
Via a network or locally? If it is from other computers on the network, then you will probably want to configure Samba on your Ubuntu computer.
https://help.ubuntu.com/11.10/serverguide/C/samba-fileserver.html
If you are dual booting the computer and want to access Ubuntu from Windows, you could try ext2read. I haven't tested it, but it apparently supports most standard Linux file systems.
The other option is to boot off a live CD / USB stick. Then you will be able to copy the files off to another location. Maybe another USB device or network location.
Eliah Kagan
  • 119,640
