I have a 128 GB SSD and 1 TB HDD. I made two partitions on the SSD, one containing Windows 10 (pre-installed) and other empty. I want to install Ubuntu on the empty partition of the SSD.
If I do that, will I be able to access the HDD from either of the OSs? If so, how can I do it? Please explain in detail...
I need both OSes because I want Windows 10 for gaming and Ubuntu for programming.
Zanna
  • 72,312
yes you can install ubuntu from another partition together with windows in ssd drive.
you can access partition on hdd in windows or linux ..
but i suggest to turn off fasboot mode in advanced power options(windows). becouse some time if you try bootup to linux. you can see file/folder on hdd . but you can't write, edit or delete it.
or
you can change filesystem on hdd partition to "exfat" and install "extfat-utils" to support mount hdd in linux.. if you want fastboot active and write to hdd drive in linux.
