I am using Ubuntu version 16.04. It all started when I wanted to test out a pre-release of a software called QGIS. I was having trouble updating it to the new version (2.99) and it recommended that I should uninstall the current version (2.18), which is what I did.
Now, I can install neither the 2.99 version, nor the 2.18 one. I just want to get version 2.18 reinstalled because I really need it.
Basically, to install QGIS 2.18, I used the following commands:
sudo apt-get update
sudo apt-get install qgis python-qgis qgis-plugin-grass
But when I do, I get this error:
Reading package lists... Done
Building dependency tree
 python-qgis : Depends: python-qscintilla2 but it is not going to be installed
 qgis-plugin-grass : Depends: grass703
I have tried to install grass703 manually (the package name is actually grass-core), but it says that it is already at the latest version (7.2.1-1~xenial1).
I have also tried to look for held packages with the command dpkg --get-selections | grep hold, which doesn't return anything.
I found what seemed to be the same problem here, but I tried the suggestion in the only answer, which did not work. The only other feedback was (in my opinion a rather snarky and unhelpful berating), telling them to uninstall all packages from that source. I installed purge-ppa and removed everything from the non-ubuntu source (-o ubuntugis, referring to the ubuntugis team, which I had previously installed some packages from to try and make the 2.99 version of QGIS work.) Still no help, and QGIS itself will not install.
No amount of sudo apt-get update will seem to solve this problem and I am getting desperate. Does anyone have any idea how I can fix this? I really need to get QGIS installed again in some working capacity.
This is the contents of my /etc/apt/sources.list:
# deb cdrom:[Xubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719)]/ xenial main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://de.archive.ubuntu.com/ubuntu/ xenial main restricted
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://de.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://de.archive.ubuntu.com/ubuntu/ xenial universe
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial universe
deb http://de.archive.ubuntu.com/ubuntu/ xenial-updates universe
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://de.archive.ubuntu.com/ubuntu/ xenial multiverse
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial multiverse
deb http://de.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://de.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
# deb-src http://de.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
deb http://security.ubuntu.com/ubuntu xenial-security main restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu xenial-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
deb http://qgis.org/debian xenial main
deb-src http://qgis.org/debian xenial main
#deb http://qgis.org/debian-nightly xenial main
#deb-src http://qgis.org/debian-nightly xenial main
#deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu xenial main
and this is the content of sources.list.d/:
-rw-r--r-- 1 root root 146 Jan  5 12:49 colingille-ubuntu-freshlight-xenial.list
-rw-r--r-- 1 root root 146 Jan  5 12:49 colingille-ubuntu-freshlight-xenial.list.save
-rw-r--r-- 1 root root 222 Jan  5 12:49 cooperjona-ubuntu-nitrotasks-xenial.list
-rw-r--r-- 1 root root 222 Jan  5 12:49 cooperjona-ubuntu-nitrotasks-xenial.list.save
-rw-r--r-- 1 root root 158 Jan  5 12:49 fyrmir-ubuntu-livewallpaper-stable-xenial.list
-rw-r--r-- 1 root root 158 Jan  5 12:49 fyrmir-ubuntu-livewallpaper-stable-xenial.list.save
-rw-r--r-- 1 root root 189 Jan  5 12:49 google-chrome.list
-rw-r--r-- 1 root root 189 Jan  5 12:49 google-chrome.list.save
-rw-r--r-- 1 root root 175 Jan  5 12:49 google-earth.list
-rw-r--r-- 1 root root 175 Jan  5 12:49 google-earth.list.save
-rw-r--r-- 1 root root 180 Jan  5 12:49 google-talkplugin.list
-rw-r--r-- 1 root root 180 Jan  5 12:49 google-talkplugin.list.save
-rw-r--r-- 1 root root 150 Jan  5 12:49 kakrueger-ubuntu-openstreetmap-xenial.list
-rw-r--r-- 1 root root 150 Jan  5 12:49 kakrueger-ubuntu-openstreetmap-xenial.list.save
-rw-r--r-- 1 root root 146 Jan  5 12:49 kubuntu-ppa-ubuntu-backports-xenial.list
-rw-r--r-- 1 root root 146 Jan  5 12:49 kubuntu-ppa-ubuntu-backports-xenial.list.save
-rw-r--r-- 1 root root  89 Jan  5 12:49 lightzone.list
-rw-r--r-- 1 root root  89 Jan  5 12:49 lightzone.list.save
-rw-r--r-- 1 root root 501 Jan  5 12:49 mysql.list
-rw-r--r-- 1 root root 500 Jan  5 12:49 mysql.list.save
-rw-r--r-- 1 root root 246 Jan  5 12:49 nathan-renniewaldock-ubuntu-qdirstat-xenial.list
-rw-r--r-- 1 root root 246 Jan  5 12:49 nathan-renniewaldock-ubuntu-qdirstat-xenial.list.save
-rw-r--r-- 1 root root 144 Jan  5 12:49 nilarimogard-ubuntu-webupd8-xenial.list
-rw-r--r-- 1 root root 144 Jan  5 12:49 nilarimogard-ubuntu-webupd8-xenial.list.save
-rw-r--r-- 1 root root 124 Jan  5 12:49 pgdg.list
-rw-r--r-- 1 root root 124 Jan  5 12:49 pgdg.list.save
-rw-r--r-- 1 root root 207 Jan  5 12:49 pipelight-ubuntu-stable-xenial.list
-rw-r--r-- 1 root root 207 Jan  5 12:49 pipelight-ubuntu-stable-xenial.list.save
-rw-r--r-- 1 root root 126 Jan  5 12:49 shutter-ubuntu-ppa-xenial.list
-rw-r--r-- 1 root root 126 Jan  5 12:49 shutter-ubuntu-ppa-xenial.list.save
-rw-r--r-- 1 root root  56 Jan  5 12:49 skype-stable.list
-rw-r--r-- 1 root root  56 Jan  5 12:49 skype-stable.list.save
-rw-r--r-- 1 root root 148 Jan  5 12:49 steam.list
-rw-r--r-- 1 root root 148 Jan  5 12:49 steam.list.save
-rw-r--r-- 1 root root 198 Jan  5 12:49 ubuntugis-ubuntu-ppa-xenial.list
-rw-r--r-- 1 root root 130 Jan  5 12:49 ubuntugis-ubuntu-ppa-xenial.list.save
-rw-r--r-- 1 root root 136 Jan  5 12:49 webupd8team-ubuntu-java-xenial.list
-rw-r--r-- 1 root root 136 Jan  5 12:49 webupd8team-ubuntu-java-xenial.list.save
-rw-r--r-- 1 root root 136 Jan  5 12:49 wine-ubuntu-wine-builds-xenial.list
-rw-r--r-- 1 root root 136 Jan  5 12:49 wine-ubuntu-wine-builds-xenial.list.save
The results of aptitude search ?obsolete:
i   fme-desktop-2017                                       - FME Desktop 2017.1.2 Full Installer
i   geoda                                                  - GeoDa Software
i   google-earth-stable                                    - Explore, search and discover the planet
i   hl3040cncupswrapper:i386                               - Brother CUPS Inkjet Printer Definitions
i   hl3040cnlpr:i386                                       - Brother lpr Inkjet Printer Definitions
i   projectlibre                                           - A desktop replacement for Microsoft Project
i   rainlendar2-lite                                       - Customizable desktop calendar
i   rstudio                                                - RStudio
Output of grep -v "^#" -r /etc/apt/sources.list /etc/apt/sources.list.d/*.list | sort | uniq::
/etc/apt/sources.list.d/colingille-ubuntu-freshlight-xenial.list:deb http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial main
/etc/apt/sources.list.d/cooperjona-ubuntu-nitrotasks-xenial.list:deb http://ppa.launchpad.net/cooperjona/nitrotasks/ubuntu xenial main
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial main restricted
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial multiverse
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial universe
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ xenial-updates universe
/etc/apt/sources.list:deb http://qgis.org/debian xenial main
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu xenial-security main restricted
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu xenial-security multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu xenial-security universe
/etc/apt/sources.list:deb-src http://qgis.org/debian xenial main
/etc/apt/sources.list.d/fyrmir-ubuntu-livewallpaper-stable-xenial.list:deb http://ppa.launchpad.net/fyrmir/livewallpaper-stable/ubuntu xenial main
/etc/apt/sources.list.d/google-chrome.list:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list.d/google-earth.list:deb http://dl.google.com/linux/earth/deb/ stable main
/etc/apt/sources.list.d/google-talkplugin.list:deb http://dl.google.com/linux/talkplugin/deb/ stable main
/etc/apt/sources.list.d/kakrueger-ubuntu-openstreetmap-xenial.list:deb http://ppa.launchpad.net/kakrueger/openstreetmap/ubuntu xenial main
/etc/apt/sources.list.d/kubuntu-ppa-ubuntu-backports-xenial.list:deb http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu xenial main
/etc/apt/sources.list.d/lightzone.list:deb http://download.opensuse.org/repositories/home:/ktgw0316:/LightZone/xUbuntu_15.10/ /
/etc/apt/sources.list.d/mysql.list:deb http://repo.mysql.com/apt/ubuntu/ xenial mysql-5.7
/etc/apt/sources.list.d/mysql.list:deb http://repo.mysql.com/apt/ubuntu/ xenial mysql-apt-config
/etc/apt/sources.list.d/mysql.list:deb http://repo.mysql.com/apt/ubuntu/ xenial mysql-tools
/etc/apt/sources.list.d/mysql.list:deb-src http://repo.mysql.com/apt/ubuntu/ xenial mysql-5.7
/etc/apt/sources.list.d/nathan-renniewaldock-ubuntu-qdirstat-xenial.list:deb http://ppa.launchpad.net/nathan-renniewaldock/qdirstat/ubuntu xenial main
/etc/apt/sources.list.d/nilarimogard-ubuntu-webupd8-xenial.list:deb http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu xenial main
/etc/apt/sources.list.d/pgdg.list:deb http://apt.postgresql.org/pub/repos/apt/ xenial-pgdg main
/etc/apt/sources.list.d/pipelight-ubuntu-stable-xenial.list:deb http://ppa.launchpad.net/pipelight/stable/ubuntu xenial main
/etc/apt/sources.list.d/shutter-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/shutter/ppa/ubuntu xenial main
/etc/apt/sources.list.d/skype-stable.list:deb [arch=amd64] https://repo.skype.com/deb stable main
/etc/apt/sources.list.d/steam.list:deb [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
/etc/apt/sources.list.d/steam.list:deb-src [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
/etc/apt/sources.list.d/ubuntugis-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/ubuntugis/ppa/ubuntu xenial main
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list:deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
/etc/apt/sources.list.d/wine-ubuntu-wine-builds-xenial.list:deb http://ppa.launchpad.net/wine/wine-builds/ubuntu xenial main
double-beep
  • 195
  • 13
wfgeo
  • 143
During chat we did the following steps to fix the problem:
  1. Disabled obsolete repositories from software-properties-gtk:
download.opensuse.org/...
ppa.launchpad.net/colingille/...
ppa.launchpad.net/cooperjona/...
ppa.launchpad.net/kakrueger/...
  1. Purged two PPAs with
    sudo ppa-purge ppa:ubuntugis/ppa
    sudo ppa-purge ppa:kubuntu-ppa/backports
    sudo apt-get install -f
    sudo dpkg --configure -a
second of them made problem with python-qscintilla2
  1. Then installed QGIS from qgis.org repository with the following command
  2. Launched QGIS and checked system integrity with
    sudo apt-get check
N0rbert
  • 103,263
