i tried reinstalling QGIS after not being able to find a plugin in the plugin manager. Now it seems that i cannot install anything anymore. Somehow also my gedit is gone and i can't install it anymore... when i try to install:
sudo apt-get install qgis python-qgis
i get:
Reading package lists... Done
Building dependency tree
qgis is already the newest version.
 python-qgis : Depends: python-qt4 but it is not going to be installed
               Depends: python-sip but it is not going to be installed
               Depends: python-qgis-common (= 2.0.1-2build2) but it is not going to be installed
               Depends: python-psycopg2 but it is not going to be installed
               Depends: python-qscintilla2 but it is not going to be installed
               Depends: python-pyspatialite but it is not going to be installed
               Depends: python:any (>= 2.7.1-0ubuntu2)
               Depends: sip-api-11.0
I have tried most recommendations in the forums but nothing has worked so far. unfortunately i am also not experienced with Linux. I would be very glad about some help!
My suggestion is to run sudo apt-get -f install. It should walk down the dependency tree and install any missing or broken packages. If that doesn't work, try to manually install the packages by running the command:sudo apt-get install python-qt4 python-sip python-qgis-common python-psycopg2 python-qscintilla2 python-pyspatialite python:any sip-api-11.0. If that fails, than there is something wrong with the system. As a last resort, I suggest running a release upgrade to 17.04 by running sudo do-release-upgrade and fix the problem.
