Seems to be the same to :
But i didn't succeed with explanations.
I am using Ubuntu 20.04.3 LTS. I was using QGis version 3.16 on a computer and have a SRC problem. This problem wasn't encountered on other computer with same ubuntu but QGis 3.22. So I want to install Qgis 3.22. I've installed 3.22 whitout uninstalling 3.16 but some installation problems appears. So I've uninstall 3.16 and try installing 3.22 but have some issues i'm know not able to solve after some researches.
I have followed this tutoriel to instal QGis : https://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
So after this command line :
sudo apt install qgis qgis-plugin-grass
I get this error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
qgis-plugin-grass : Depends: grass782
I have tried to install grass782 manually :
sudo apt install grass782
Returns :
Package grass782 is a virtual package provided by:
grass-core 7.8.2-1build3 [Not candidate version]
E: Package 'grass782' has no installation candidate
I have tried to install grass-core manually :
sudo apt install grass-core
Returns :
grass-core is already the newest version (7.8.6-1~focal2).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
When I do :
grep -v "^#" -r /etc/apt/sources.list /etc/apt/sources.list.d/*.list | sort | uniq /etc/apt/sources.list
I get :
etc/apt/sources.list:deb [arch=amd64] https://qgis.org/ubuntu focal main
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal main restricted
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal multiverse
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal universe
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal-updates main restricted
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal-updates multiverse
/etc/apt/sources.list:deb http://fr.archive.ubuntu.com/ubuntu/ focal-updates universe
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu focal-security main restricted
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu focal-security multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu focal-security universe
/etc/apt/sources.list.d/spotify.list:deb http://repository.spotify.com stable non-free
Looking for held packages with the command dpkg --get-selections | grep hold, it doesn't return anything.
After command apt-cache policy grass782 :
grass782:
Installed: (none)
Candidate: (none)
Version table:
After command apt-cache policy grass-core :
grass-core:
Installed: 7.8.6-1~focal2
Candidate: 7.8.6-1~focal2
Version table:
*** 7.8.6-1~focal2 100
100 /var/lib/dpkg/status
7.8.2-1build3 500
500 http://fr.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
After aptitude search ?obsolete :
i atom - A hackable text editor for the 21st Century.
i forticlient - FortiClient, now available on Linux, is an endpoint protection applic
i A libgdal30 - Geospatial Data Abstraction Library
i A libgeos3.10.1 - Geometry engine for Geographic Information Systems - C++ Library
i A libotbapplicationengine-7.2-1 - ORFEO Toolbox library - OTBApplicationEngine
i A libotbcarto-7.2-1 - ORFEO Toolbox library - OTBCarto
i A libotbcommandline-7.2-1 - ORFEO Toolbox library - OTBCommandLine
i A libotbcommon-7.2-1 - ORFEO Toolbox library - OTBCommon
i A libotbcurladapters-7.2-1 - ORFEO Toolbox library - OTBCurlAdapters
i A libotbextendedfilename-7.2-1 - ORFEO Toolbox library - OTBExtendedFileName
i A libotbfuzzy-7.2-1 - ORFEO Toolbox library - OTBFuzzy
i A libotbgdaladapters-7.2-1 - ORFEO Toolbox library - OTBGdalAdapters
i A libotbice-7.2-1 - ORFEO Toolbox library - OTBIce
i A libotbimagebase-7.2-1 - ORFEO Toolbox library - OTBImageBase
i A libotbimageio-7.2-1 - ORFEO Toolbox library - OTBImageIO
i A libotbimagemanipulation-7.2-1 - ORFEO Toolbox library - OTBImageManipulation
i A libotbiobsq-7.2-1 - ORFEO Toolbox library - OTBIOBSQ
i A libotbiogdal-7.2-1 - ORFEO Toolbox library - OTBIOGDAL
i A libotbiokml-7.2-1 - ORFEO Toolbox library - OTBIOKML
i A libotbiolum-7.2-1 - ORFEO Toolbox library - OTBIOLUM
i A libotbiomstar-7.2-1 - ORFEO Toolbox library - OTBIOMSTAR
i A libotbioonera-7.2-1 - ORFEO Toolbox library - OTBIOONERA
i A libotbiorad-7.2-1 - ORFEO Toolbox library - OTBIORAD
i A libotblearningbase-7.2-1 - ORFEO Toolbox library - OTBLearningBase
i A libotbmapla-7.2-1 - ORFEO Toolbox library - OTBMapla
i A libotbmathparser-7.2-1 - ORFEO Toolbox library - OTBMathParser
i A libotbmathparserx-7.2-1 - ORFEO Toolbox library - OTBMathParserX
i A libotbmetadata-7.2-1 - ORFEO Toolbox library - OTBMetadata
i A libotbmonteverdi-7.2-1 - ORFEO Toolbox library - OTBMonteverdi
i A libotbmonteverdicore-7.2-1 - ORFEO Toolbox library - OTBMonteverdiCore
i A libotbmonteverdigui-7.2-1 - ORFEO Toolbox library - OTBMonteverdiGUI
i A libotbossimadapters-7.2-1 - ORFEO Toolbox library - OTBOssimAdapters
i A libotbossimplugins-7.2-1 - ORFEO Toolbox library - OTBOssimPlugins
i A libotbpolarimetry-7.2-1 - ORFEO Toolbox library - OTBPolarimetry
i A libotbprojection-7.2-1 - ORFEO Toolbox library - OTBProjection
i A libotbqtadapters-7.2-1 - ORFEO Toolbox library - OTBQtAdapters
i A libotbqtwidget-7.2-1 - ORFEO Toolbox library - OTBQtWidget
i A libotbsampling-7.2-1 - ORFEO Toolbox library - OTBSampling
i A libotbsiftfast-7.2-1 - ORFEO Toolbox library - OTBSiftFast
i A libotbstatistics-7.2-1 - ORFEO Toolbox library - OTBStatistics
i A libotbstreaming-7.2-1 - ORFEO Toolbox library - OTBStreaming
i A libotbsupervised-7.2-1 - ORFEO Toolbox library - OTBSupervised
i A libotbtestkernel-7.2-1 - ORFEO Toolbox library - OTBTestKernel
i A libotbvectordatabase-7.2-1 - ORFEO Toolbox library - OTBVectorDataBase
i A libotbvectordataio-7.2-1 - ORFEO Toolbox library - OTBVectorDataIO
i A libotbwavelet-7.2-1 - ORFEO Toolbox library - OTBWavelet
i A libpdal-base12 - Point Data Abstraction Library - libpdal_base
i A libpdal-plugin-e57 - Point Data Abstraction Library - E57 plugin
i A libpdal-plugin-hdf - Point Data Abstraction Library - HDF plugin
i A libpdal-plugin-i3s - Point Data Abstraction Library - I3S plugin
i A libpdal-util12 - Point Data Abstraction Library - libpdal_util
i A libproj22 - Cartographic projection library
i rstudio - RStudio
i zoom - Zoom Cloud Meetings
I will be very thankfull if someone can try to help me. Thanks !
SOLUTIONING...
I've execute :
sudo apt -s install --reinstall grass-core=7.8.2-1build3
--> no error
sudo apt install --reinstall grass-core=7.8.2-1build3
--> OK
So I re-launch :
But :
Aborted (core dumped)
dpkg: error processing package qgis-providers (--configure):
installed qgis-providers package post-installation script subprocess returned error exit status 134
dpkg: dependency problems prevent configuration of qgis:
qgis depends on qgis-providers (= 1:3.22.2+32focal); however:
Package qgis-providers is not configured yet.
dpkg: error processing package qgis (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of qgis-plugin-grass:
qgis-plugin-grass depends on qgis (= 1:3.22.2+32focal); however:
Package qgis is not configured yet.
dpkg: error processing package qgis-plugin-grass (--configure):
dpkg: dependency problems prevent configuration of python3-qgis:
python3-qgis depends on qgis-providers (= 1:3.22.2+32focal); however:
dpkg: error processing package python3-qgis (--configure):
dependency problems - leaving unconfigured No apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because the error message i ndicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
Processing triggers for shared-mime- info (1.15-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for man-db (2.9.1-1) ...
qgis-providers
qgis
qgis-plugin-grass
python3-qgis
After sudo apt list --installed | grep qgis
libqgis-3d3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgis-analysis3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgis-app3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgis-core3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgis-customwidgets/now 1:3.22.2+32focal amd64 [installed,upgradable to: 1:3.22.3+32focal]
libqgis-gui3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgis-native3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgis-server3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgisgrass7-3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
libqgispython3.22.2/focal,now 1:3.22.2+32focal amd64 [installed,automatic]
otb-qgis/now 7.2.0+dfsg-1~focal3 amd64 [installed,local]
python3-qgis-common/now 1:3.22.2+32focal all [installed,upgradable to: 1:3.22.3+32focal]
python3-qgis/now 1:3.22.2+32focal amd64 [installed,upgradable to: 1:3.22.3+32focal]
qgis-plugin-grass-common/now 1:3.22.2+32focal all [installed,upgradable to: 1:3.22.3+32focal]
qgis-plugin-grass/now 1:3.22.2+32focal amd64 [installed,upgradable to: 1:3.22.3+32focal]
qgis-provider-grass/now 1:3.22.2+32focal amd64 [installed,upgradable to: 1:3.22.3+32focal]
qgis-providers-common/now 1:3.22.2+32focal all [installed,upgradable to: 1:3.22.3+32focal]
qgis-providers/now 1:3.22.2+32focal amd64 [installed,upgradable to: 1:3.22.3+32focal]
After sudo dpkg --dry-run -P $(dpkg -l | grep qgis | awk '{print $2}')
(Reading database ... 252958 files and directories currently installed.)
Would remove or purge otb-qgis (7.2.0+dfsg-1~focal3) ...
Would remove or purge qgis-plugin-grass (1:3.22.2+32focal) ...
Would remove or purge qgis-plugin-grass-common (1:3.22.2+32focal) ...
Would remove or purge qgis-provider-grass (1:3.22.2+32focal) ...
Would remove or purge libqgisgrass7-3.22.2 (1:3.22.2+32focal) ...
Would remove or purge qgis (1:3.22.2+32focal) ...
Would remove or purge qgis-common (1:3.22.2+32focal) ...
Would remove or purge libqgis-app3.22.2 (1:3.22.2+32focal) ...
Would remove or purge python3-qgis (1:3.22.2+32focal) ...
Would remove or purge python3-qgis-common (1:3.22.2+32focal) ...
Would remove or purge qgis-providers (1:3.22.2+32focal) ...
Would remove or purge qgis-providers-common (1:3.22.2+32focal) ...
Would remove or purge libqgis-3d3.22.2 (1:3.22.2+32focal) ...
Would remove or purge libqgis-analysis3.22.2 (1:3.22.2+32focal) ...
Would remove or purge libqgis-customwidgets (1:3.22.2+32focal) ...
Would remove or purge libqgis-gui3.22.2 (1:3.22.2+32focal) ...
Would remove or purge libqgis-native3.22.2 (1:3.22.2+32focal) ...
Would remove or purge libqgis-server3.22.2 (1:3.22.2+32focal) ...
Would remove or purge libqgispython3.22.2 (1:3.22.2+32focal) ...
Would remove or purge libqgis-core3.22.2 (1:3.22.2+32focal) ...
dpkg -l| egrep -v '^ii|rc'
iU python3-qgis 1:3.22.2+32focal amd64 Python bindings to QGIS
iU qgis 1:3.22.2+32focal amd64 Geographic Information System (GIS)
iU qgis-plugin-grass 1:3.22.2+32focal amd64 GRASS plugin for QGIS
iF qgis-providers 1:3.22.2+32focal amd64 collection of data providers to QGIS
