Steam Won't boot
Repairing installation, linking /home/brent/.steam/steam to /home/brent /.local/share/Steam
Running Steam on ubuntu 12.04 64-bit
STEAM_RUNTIME is enabled automatically
/home/brent/.local/share/Steam/steam.sh: line 431: realpath: command not found
/home/brent/.local/share/Steam/ubuntu12_32/steamui.so: /usr/lib/i386-linux-gnu/libstdc++.so.6: version ``GLIBCXX_3.4.18' not found (required by /home/brent/.local/share/Steam/ubuntu12_32/libtier0_s.so)
/home/brent/.local/share/Steam/ubuntu12_32/steamui.so: /usr/lib/i386-linux-gnu/libstdc++.so.6: version ``GLIBCXX_3.4.18' not found (required by /home/brent/.local/share/Steam/ubuntu12_32/libvideo.so)
/home/brent/.local/share/Steam/ubuntu12_32/steam: /usr/lib/i386-linux-gnu/libstdc++.so.6: version ``GLIBCXX_3.4.18' not found (required by /home/brent/.local/share/Steam/ubuntu12_32/steam)
/home/brent/.local/share/Steam/steam.sh: line 616: no match: ssfn*
This is after trying to Reinstall to try to fix it, Now it won't show anything after attempting to start up.
in that situation, the best you can you is to PURGE (delete Steam completely) from your system and then re-install it, here are two links that might be helpful:
Hope it helps, good luck!
galoget
  • 3,023
