11
I'm currently running Ubuntu 12.10 on Wubi, and am trying to install Steam.
Notably, when I am trying to "buy" steam from the store, it reads
Package Dependencies cannot be resolved
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
Opening the details shows this:
steam64: Depends: steam (= 1.0.0.26) but it is not going to be installed
I've read online that I need to update Ubuntu 12.10. I have done both methods, both using Software Update and the manual update (via sudo apt-get update/upgrade). Everything's up to date, and yet I cannot install Steam.
Any fixes?
yuritsuki
  • 246
steam64 is just a virtual package for the i386 steam package of the same version.
By default, x64 Wubi (and normal?) installs don't have i386 support enabled, which is required by the steam package. To enable it, you can do this at a terminal:
sudo dpkg --add-architecture i386
sudo apt-get update
As of this writing, the steam and steam64 debs in the software center are out of date (1.0.0.26) and contain Beta warnings. These warnings have been removed in the .deb on the Steam site (1.0.0.27).
Powerlord
  • 536
All right, I've figured this out.
What you need to do before trying to download Steam is to update your system. You can do this two ways, either by going to the top left hand corner and clicking the dashboard icon and then searching for Update and using it; or, manually:
sudo apt-get update
sudo apt-get upgrade
Afterwards, do not install Steam from the Ubuntu Software Centre. It is extremely buggy, and in most cases will not work for you. (I had everything up-to-date in terms of update, yet it kept giving me the same problems.
Install steam from its homepage: Steam. You should be good to go.
belacqua
  • 23,540
yuritsuki
  • 246
You can go to the Ubuntu Software center, then go to
edit>Software Sources
Check the options:
  • Downloadable from internet
  • like main
  • restricted
  • universe
  • multiverse
Go to tab Other Software and check canonical partner,and indepedent software. Go to terminal and type:
sudo apt-get update
sudo apt-get install steam64
sudo dpkg --configure -a
yuritsuki
  • 246
Baim
  • 245
