I've got a Blu-ray drive and I'd like to be able to use it to watch movies under Ubuntu.
Please see the following official documentation for Bluray disc playback on Ubuntu:
- 73,717
- 1,293
makemkv is what i use on linux to rip and then play blu-ray discs. It works very well, and it's free at the moment. Makemkv will convert any dvd or blu-ray disc to an mkv file. DVDs rip into files of around 5GB, while bluray disks will give you huge files of 30-40GB. From there, i use handbrake to compress the video (including several audio/subtitle tracks) for viewing on tv/ipad/laptop.
Installation instructions are here: http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
- 1,801
- 1
- 15
- 16
It is actually possible if you use the media center application called xbmc which can be found here.
https://launchpad.net/~team-xbmc/+archive/ppa
After you have installed the package their is a plugin for xbmc to read bluray disks. The instructions are here.
http://bloggingabout.com/bluray-playback-xbmc-plugin.html
OMGUBUNTU.CO.UK also has a very simple script to get it setup with VLC also which is at the below link.
http://www.omgubuntu.co.uk/2010/10/easy-blu-ray-movie-playback-in-linux/
- 1,085
Blu ray discs are currently unsupported on Linux. There are ways to play them but they require using methods of circumventing DRM and isnt exactly user friendly in the first place.
Look at this for an explanation on how to play the disc
https://help.ubuntu.com/community/RestrictedFormats/BluRayAndHDDVD
- 129
- 7
lxBDPlayer player works fine for unencrypted Bluray discs.
They have a .deb installer on their homepage and on sourceforge.
I even mounted an untouched BluRay ISO and opened it with this player.
The player only has some very basic features like start, stop, pause, skip and chapter selection, but it is easy to install and easy to use.
- 105
- 4
- 482
As of Ubuntu 16.04 you can use a 30 day trial of MakeMKV
Install makemkv
cd ~/Downloads
wget http://www.makemkv.com/download/makemkv-bin-1.9.10.tar.gz
wget http://www.makemkv.com/download/makemkv-oss-1.9.10.tar.gz
sudo tar -xvzf makemkv-bin-1.9.10.tar.gz
sudo tar -xvzf makemkv-oss-1.9.10.tar.gz
sudo apt install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev libqt4-dev -y
cd ~/Downloads/makemkv-oss-1.9.10
sudo ./configure
sudo make
sudo make install
cd ~/Downloads/makemkv-bin-1.9.10
sudo make
Accept terms
sudo make install
cd
makemkv
Start Stream
makemkv
Then
Open Disc > File > Stream
Then
Play Stream
vlc http://localhost:51000/stream/title0.ts
More detailed instructions here:
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=14633#p49831
- 3,984
