Possible Duplicate:
How can I watch Blu-ray discs?
How can i play Bluray discs on Ubuntu 12.04 64bit?
When i put the disc in my laptop it doesn't even get mounted.
jeggy@localhost:~$ sudo fdisk -l
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0009f0f2
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048      206847      102400    7  HPFS/NTFS/exFAT
/dev/sda2          206848   195518463    97655808    7  HPFS/NTFS/exFAT
/dev/sda3       195520510   976771071   390625281    5  Extended
/dev/sda5       195520512   218957823    11718656   82  Linux swap / Solaris
/dev/sda6       218959872   976771071   378905600   83  Linux
I have a Dell XPS 15 which should be able to play bluray discs.
This is what it says on Official Dell site
8x DVD+/-RW (standard), Blu-ray Discâ„¢ combo (reads Blu-ray Discâ„¢ & writes to CD/DVD); 12.7mm tray load
Jeggy
  • 3,122
  • 16
  • 57
  • 80
