Problem:
I am trying to play a bluray disk on my Sony Vaio Laptop running Ubuntu 12.04.2. I have tried many tutorials on how to do this and actually I was able to play 1 scene once. But after reboot it stopped working again.
What I have tried:
I did try anything suggested in this question and also tried to manually mount the disk. Both failed. I can run some termina command when no blu-ray is in the drive:
$wodim --devices
wodim: Overview of accessible drives (1 found) :
 0  dev='/dev/sg1'  rwrw-- : 'PIONEER' 'BD-RW   BDR-TD04'
$ sudo lshw -c disk
  *-cdrom
       description: DVD-RAM writer
       product: BD-RW   BDR-TD04
       vendor: PIONEER
       physical id: 0.0.0
       bus info: scsi@4:0.0.0
       logical name: /dev/cdrom
       logical name: /dev/cdrw
       logical name: /dev/dvd
       logical name: /dev/dvdrw
       logical name: /dev/sr0
       version: 1.00
       capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
       configuration: ansiversion=5 status=nodisc
A dmesg | tail returns me many of these error blocks when a disk is inserted:
[ 2172.584143] sr 4:0:0:0: [sr0] Unhandled sense code
[ 2172.584158] sr 4:0:0:0: [sr0]
[ 2172.584160] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 2172.584161] sr 4:0:0:0: [sr0]
[ 2172.584162] Sense Key : Medium Error [current]
[ 2172.584164] Info fld=0x0
[ 2172.584165] sr 4:0:0:0: [sr0]
[ 2172.584167] Add. Sense: L-EC uncorrectable error
[ 2172.584168] sr 4:0:0:0: [sr0] CDB:
[ 2172.584169] Read(10): 28 00 00 00 00 00 00 00 02 00
[ 2172.584173] end_request: I/O error, dev sr0, sector 0
[ 2172.584176] Buffer I/O error on device sr0, logical block 0
I found more on this issue in an archlinux and openSUSE forum but both questions did not help me. Without a disk in the drive all a dmesg | grep sr0 returns is:
[    1.345366] sr0: scsi3-mmc drive: 62x/62x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.345556] sr 4:0:0:0: Attached scsi CD-ROM sr0
libdvdcss is installed. So are libbluray1, libbluray-dbg and libaacs0. I also used this guied to patch my KEYDB.cfg and my libaacs0.so
I also tried the lxBDPlayer without success.
Question
I've read that this problem might be the result of a broken drive or a broken disk. The disk is brand new and should be fine (I also checked it for scratches etc.) and since the drive successfully plays audio-cds and DVDs I don't see how the drive can be broken. Is there anything you can suggest me to try. Any guide or tutorial you know about how to run bluray on ubuntu that I might have not tried yet?
If you need further information feel free to ask.
Edit:
I just tried another bluray disk with the following result: error message
Running dmesg |grep sr0 returns still similar results:
$ dmesg |grep sr0
[ 7593.402746] sr 4:0:0:0: [sr0] Unhandled sense code
[ 7593.402761] sr 4:0:0:0: [sr0]
[ 7593.402764] sr 4:0:0:0: [sr0]
[ 7593.402768] sr 4:0:0:0: [sr0]
[ 7593.402771] sr 4:0:0:0: [sr0] CDB:
[ 7593.402776] end_request: I/O error, dev sr0, sector 1024
[ 7593.402779] Buffer I/O error on device sr0, logical block 128
[ 7607.672659] sr 4:0:0:0: [sr0] Unhandled sense code
[ 7607.672663] sr 4:0:0:0: [sr0]
[ 7607.672666] sr 4:0:0:0: [sr0]
[ 7607.672670] sr 4:0:0:0: [sr0]
[ 7607.672674] sr 4:0:0:0: [sr0] CDB:
[ 7607.672679] end_request: I/O error, dev sr0, sector 1280
[ 7607.672695] UDF-fs: error (device sr0): udf_read_tagged: read failed, block=320, location=0
[ 7607.672699] UDF-fs: warning (device sr0): udf_fill_super: No fileset found
The drive is now responding to e.g. lshw -c disk
  *-cdrom
       vendor: PIONEER
       physical id: 0.0.0
       version: 1.00
       configuration: ansiversion=5 status=ready
     *-medium
      physical id: 0
I wonder why the name is /dev/cdrom and not /dev/dvd? When I try to open the disk with VLC the following error pops up in the VLC console:
Blu-Ray error:
Path doesn't appear to be a bluray
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///dev/cdrom'. Check the log for details.
byf-ferdy
  • 416
Try MakeMKV and VLC with the extra plugins from 'gnome software'. HOWEVER, use the flatpak versions for both programs.
No extra downloads.. it just works. At least on the late model versions of Ubuntu.
I don't think that there is a problem mounting Read-Only. CD's (DVD's, etc) are "read-only" discs, so mounting them read-only makes sense.
When you said that you've tried lxBDPlayer, did you also load the extra plugin, and software that makes work?
to use lxbdplayer, you will need to download the following:
  • The lxbdplayer itself. This package is a .deb for Ubuntu and Debian.
  • The AACSKeys plugin for lxbdplayer.
  • The MakeMKV package (this is the 64-bit version. To get the 32-bit version, click here).
  • The ShowKeys library (this is the 64-bit version. To get the 32-bit version, click here).
To install the packages, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo dpkg -i lxbdplayer_0.2.1_all.deb lxbdaacs_0.2.1_all.deb makemkv_1.5.5b_amd64.deb libshowkeys_v1.5.5_amd64.deb
You might need to download a couple of dependencies, but otherwise the installation is small and quick.
Once the install is complete, import the decryption keys needed by typing in the following command:
bdkey-install
Note: You may need to have the drive’s firmware patched.
Source:The HyRax Macrocosm
Mitch
  • 109,787
