I wanted to set keyboard shortcut for tor browser.
So i need a command which opens tor browser.
I installed .tar.gz file of tor browser,which installed in my home directory:
/home/sina/tor-browser-linux
So the file which i should set keyboard shortcut is this directory:
/home/sina/tor-browser-linux/tor-browser_en-US/Tor\ Browser
I wanted to open tor browser via terminal in these way:
sina@msi:~$ ./home/sina/tor-browser-linux/tor-browser_en-US/Tor\ Browser
bash: ./home/sina/tor-browser-linux...: No such file or directory
I tried to solve it by reading this link(like i did it for telegram before):
How to run Telegram from Terminal
I tried to do this for tor(instead of telegram):
sina@msi:~$ nano ~/.profile
I added this to the last line of .profile:
export PATH="/home/sina/tor-browser-linux/tor-browser_en-US/start-tor-browser.desktop"
It didn't work!
sina@msi:~$ sudo ln -s /home/sina/tor-browser-linux/tor-browser_en-US/start-tor-browser.desktop /usr/local/bin
sina@msi:~$ sudo ln -s /home/sina/tor-browser-linux/tor-browser_en-US/start-tor-browser.desktop /usr/share/applications
sina@msi:~$ cp /usr/share/applications/start-tor-browser.desktop ~/.config/autostart
I tried this too:
sina@msi:~$ alias tor='/home/sina/tor-browser-linux/tor-browser_en-US/start-tor-browser.desktop'
sina@msi:~$ tor
/usr/bin/env: ‘./Browser/execdesktop’: No such file or directory
When i cd to the tor browser's directory and run this command:
sina@msi:~/tor-browser-linux/tor-browser_en-US$ ./start-tor-browser.desktop
Tor browser opens and works...but when i run this:
sina@msi:~$ ./tor-browser-linux/tor-browser_en-US/start-tor-browser.desktop
I have start-tor-browser.desktop in my home directory,and i can open it with thunar,but not with terminal:
sina@msi:~$ ./start-tor-browser.desktop
  • Is there any command to open tor browser via terminal?
Sss
  • 1,032
The path to run tor-browser is (taken from [start-tor-browser].desktop file)
[unzipped tar archive]/tor-browser_en-US/Browser/start-tor-browser --detach
p.s.: you didn't specify which desktop manager you have or which distro.
If you have LXDM/lightdm/lubuntu** then edit this file:
[homefolder]/.config/openbox/lxde-rc.xml
You will see lots of sections <keybind>...</keybind>; add underneath one of them your keybind like so:
<keybind key="C-A-T">
    <action name="Execute">
        <command>[path to where you unzipped the tar archive]/tor-browser_en-US/Browser/start-tor-browser --detach</command>
    </action>
</keybind>
Save and exit and run the following inside terminal:
openbox --reconfigure
Edit
Regarding Xfce shortcuts see these links:
