19
So I have telegram messenger on my Ubuntu and I'm trying to launch it from terminal and later on set it up as startup program - problem is I cannot find command to run it. telegram/Telegram don't work.
This is how I installed this app:
sudo add-apt-repository ppa:atareao/telegram
sudo apt-get update
sudo apt-get install telegram
Thank you for any help.
muru
  • 207,228
The app is installed in
/opt/telegram/
and the binary is
/opt/telegram/Telegram
To start the messenger via command line, you have to use the full path or add the path to your PATH definition or create a symbolic link in /usr/bin:
  • Use the PATH
    1. Edit the file ~/.profile
      nano ~/.profile
    2. and add the line below at the end of the file
      export PATH="$PATH:/opt/telegram"
OR
  • Use a symbolic link
    sudo ln -s /opt/telegram/Telegram /usr/local/bin
You have a desktop file:
/usr/share/applications/telegram.desktop
and therefore use the command below
cp /usr/share/applications/telegram.desktop ~/.config/autostart
to create an autostart entry via command line.
Why do I know that?
% dpkg -L telegram
/usr
/usr/share
/usr/share/doc
/usr/share/doc/telegram
/usr/share/doc/telegram/copyright
/usr/share/doc/telegram/changelog.Debian.gz
/opt
/opt/telegram
/opt/telegram/telegram.tar.xz
/opt/telegram/telegram.svg
 % cat /usr/share/applications/telegram.desktop
[Desktop Entry]
Version=1.0
Type=Application
Terminal=false
Name=Telegram
Exec=/opt/telegram/Telegram
Comment=Network taking back our right to privacy.
Icon=/opt/telegram/telegram.svg
Categories=GNOME;GTK;Network;
Arda
  • 1,330
  • 15
A.B.
  • 92,125
10
If you installed using snap, try
telegram-desktop
hello
  • 101
Use a Bash alias like this:
alias tg='/opt/telegram/Telegram'
And then just type:
tg
in Terminal and it will open Telegram. You can replace tg with what you like.
You can use TelegramTUI on your terminal
