18
Lately, booting Ubuntu on my desktop has become seriously slow. We're talking two minutes. It used to take 10-20 seconds. Because of plymouth, I can't see what's going on. I would like to deactivate it, but not really uninstall it. What's the quickest way to do that? I'm using Precise, but I suspect a solution for 11.10 would work just as well.
Easiest quick fix is to edit the grub line as you boot.
Hold down the shift key so you see the menu. Hit the e key to edit
Edit the 'linux' line, remove the 'quiet' and 'splash'
To disable it in the long run
Edit /etc/default/grub
Change the line – GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash” to
GRUB_CMDLINE_LINUX_DEFAULT=""
And then update grub
sudo update-grub
Panther
  • 104,528
If you just want to see the message for a single boot (vs. a permanent change), you should be able to press the ESC key to hide the splash screen and reveal the boot console.
David C.
  • 151
Alternatively to quiet splash kernel parameters alsord.plymouth=0 plymouth.enable=0 kernel parameters can be used.
Either boot and modify parameters in grub console (c) or add to /etc/default/grub:
GRUB_CMDLINE_LINUX="rd.plymouth=0 plymouth.enable=0"
And then regenerate grub config:
# update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.10.0-28-amd64
Found initrd image: /boot/initrd.img-5.10.0-28-amd64
done
pevik
  • 483
How about pressing CTRL+ALT+F2 for console allowing you to see whats going on.. You can go back to GUI/Plymouth by CTRL+ALT+F7.
Don't have my laptop here right now, but IIRC Plymouth has upstart job in /etc/init, named plymouth???.conf, renaming that probably achieves what you want too more permanent manner.
Tuminoid
  • 3,932
