I have numerous hard drives that I boot from. I have drives for Windows 7, Windows 8.1, and Windows 10 as well as various versions of Ubuntu. Also other distros of Linux such as Kubuntu and Debian.
I have downloaded and installed Ubuntu 18.04.01 and found it painfully slow. I have tested numerous configurations to get the following numbers.
All tests have been run on the very same computer, except for swapping the drive. I have been using three identical SSDs, all purchased at the same time. I began by wiping two SSDs using Darik's Boot and Nuke (writing zeroes). Then I installed a copy of 16.04 on one and 18.04.1 on the other. The third SSD began with a fresh install of Windows 7 and then added 16.04 to it.
I also ran additional tests booting live copies of 16.04 and 18.04.1 from thumb drives (USB 2).
WiFi turned off, Ethernet cable connected.
Here are my times to boot and shutdown.
Boot times are measured from when I pushed the power button.
Windows 7: 20 seconds to boot the the desktop.
Ubuntu 16.04 from SSD: 23 seconds to boot. 3 seconds to shut down.
Ubuntu 16.04 live from thumb drive: 55 + 23 seconds. (The first time is from power on to the screen prompting if I want to try or install Ubuntu. The second is from clicking "Try Ubuntu" to the desktop.) 5 seconds to shutdown.
Ubuntu 18.04.1 from SSD: 4 minutes 40 seconds to boot. 1 minute 5 seconds to shut down.
Ubuntu 18.04.1 live from thumb drive: 6 minutes 12 seconds + 2 minutes 25 seconds. 35 seconds to shutdown.
As you can see, the performance of 18.04 is unacceptable. I did a presentation last night to some Windows users of setting up their systems to dual boot so they could try Ubuntu, but I found that I had to demonstrate the older version. None of them would have cared to ever try anything with the performance of this new version.
Here's the output from "systemd-analyze blame"
31.709s plymouth-start.service
30.298s systemd-backlight@backlight:intel_backlight.service
20.361s plymouth-quit-wait.service
20.081s apt-daily.service
3.045s NetworkManager-wait-online.service
2.923s snapd.service
2.419s apparmor.service
1.610s dev-sda1.device
862ms fwupd.service
721ms dev-loop3.device
720ms dev-loop1.device
718ms dev-loop2.device
714ms dev-loop0.device
704ms dev-loop4.device
698ms dev-loop5.device
694ms dev-loop6.device
565ms udisks2.service
553ms NetworkManager.service
482ms networkd-dispatcher.service
478ms swapfile.swap
404ms keyboard-setup.service
382ms systemd-journal-flush.service
358ms ModemManager.service
351ms systemd-journald.service
349ms systemd-udev-trigger.service
241ms dns-clean.service
238ms accounts-daemon.service
231ms plymouth-read-write.service
229ms console-setup.service
199ms gpu-manager.service
193ms avahi-daemon.service
190ms speech-dispatcher.service
186ms upower.service
181ms grub-common.service
176ms systemd-rfkill.service
166ms systemd-resolved.service
160ms snap-gnome\x2dcalculator-180.mount
157ms apport.service
155ms systemd-logind.service
155ms snap-gnome\x2dcharacters-103.mount
151ms systemd-timesyncd.service
150ms snap-gnome\x2dsystem\x2dmonitor-51.mount
146ms snap-gnome\x2dlogs-37.mount
138ms thermald.service
135ms pppd-dns.service
132ms dev-loop7.device
132ms snap-gnome\x2d3\x2d26\x2d1604-70.mount
131ms rsyslog.service
126ms snap-gtk\x2dcommon\x2dthemes-319.mount
113ms snap-core-4917.mount
108ms bolt.service
103ms wpa_supplicant.service
102ms snapd.seeded.service
101ms alsa-restore.service
80ms systemd-modules-load.service
78ms user@1000.service
75ms systemd-udevd.service
71ms polkit.service
66ms packagekit.service
63ms gdm.service
60ms systemd-random-seed.service
58ms dev-mqueue.mount
57ms sys-kernel-debug.mount
54ms dev-hugepages.mount
54ms kmod-static-nodes.service
53ms ufw.service
48ms systemd-remount-fs.service
47ms snap-core-5145.mount
46ms systemd-sysctl.service
45ms systemd-tmpfiles-clean.service
44ms systemd-tmpfiles-setup-dev.service
37ms networking.service
35ms sys-kernel-config.mount
31ms systemd-tmpfiles-setup.service
29ms colord.service
29ms kerneloops.service
28ms sys-fs-fuse-connections.mount
19ms systemd-user-sessions.service
17ms systemd-update-utmp.service
14ms ureadahead-stop.service
14ms setvtrgb.service
10ms systemd-update-utmp-runlevel.service
8ms rtkit-daemon.service
6ms systemd-backlight@leds:dell::kbd_backlight.service
4ms snapd.socket
