11
Installed a bunch of updates to my Ubuntu 17.10 desktop tonight, and rebooted. Now the media keys at the top of my DELL USB keyboard no longer work.
When I run sudo showkey it looks like the volume knob, play, stop, calculator, etc..., are still sending key down and key up events. But those don't seem to do anything anymore, as if Ubuntu is ignoring all the extra keys. Anyone have ideas?
sudo showkey
keycode 140 press # calculator
keycode 140 release
keycode 113 press # mute
keycode 113 release
keycode 166 press # stop
keycode 166 release
keycode 114 press # volume down
keycode 114 release
keycode 115 press # volume up
keycode 115 release
sudo lsusb
Bus 001 Device 004: ID 413c:2010 Dell Computer Corp. Keyboard
Bus 001 Device 002: ID 413c:1003 Dell Computer Corp. Keyboard Hub
Stéphane
  • 2,536
I had a similar problem with the media keys (mute, play, pause) after installing the Unity interface on a clean 17.10 installation. The media keys worked fine in the login screen and on the Gnome interface desktop.
The post How to find *why* I can't bind some keyboard shortcut (or which app took it)? gave me an insight for a workaround. It seems to be some issue with compiz.
I installed Compiz Config Settings Manager
sudo apt install compizconfig-settings-manager
ccsm
and disabled the plugin Commands. After that the media keys seem to be working fine.
Zanna
  • 72,312
Alex
  • 266
On Ubuntu 18.04 with Unity installed, this answer worked for me:
cd && mv .gconf .gconf.old
EDIT:
Subsequent Fix 1: Strangely, a couple weeks later, the problem came back, and while the accepted answer (disabling the "Commands" plugin) hadn't worked the first time, this time it did. Not sure that plugin got re-enabled.
Subsequent Fix 2: 19 days after the above fix, the problem returned. Toggling "Commands" plugin off and on fixed it.
Garrett
  • 730
