Today was my first contact with Linux OS (I pretty much do not know anything about Ubuntu). I installed Ubuntu 16.04.3 dual boot with windows 10 and everything was working. When I tried to change the screen brightness it went dark and the keys for changing brightness are not working.
I have already tried the following solutions:
Brightness key not working Ubuntu 16.04 LTS - Exactly same problem as me, except my laptop is Lenovo IdeaPad P400 touch
Can't change brightness in Ubuntu 16.04 LTS - Tried both the solution given by @Archisman Panigrahi and by @Serge Stroobandt
Ubuntu 14.04 brightness problem (Lenovo Z500) - tried solution given by @Lorenzo Gabriele. Solution similar to second link
That same problem happened to me on windows every time I updated the system. The solution was to go the video driver setting and apply the old version of the driver. I tried the similar thing:
Additional Drivers
But the only thing in the list is 'Unknown:unknown'. In other words, no graphical drivers as shown for the answer in this question.
Moreover, I read here that "Intel graphics driver is part of the xserver-xorg-video-intel driver package", but when I execute the following:
sudo apt-get install xserver-xorg-video-intel
I get E: Unable to correct problems, you have held broken packages. as shown below:
Reading package lists... Done
Building dependency tree
 xserver-xorg-video-intel : Depends: xorg-video-abi-20
                            Depends: xserver-xorg-core (>= 2:1.17.99.902)
I could not find a solution yet, but here is a workaround that works pretty well. I took the steps belows to control brightness from the keyboard with brightness-indicator software:
  1. Download and install Intel Graphics Update Tool for Linux
    Run the tool to dowwload and upgrade drivers
  2. Get and update latest mesa drivers
    sudo add-apt-repository ppa:ubuntu-x-swat/updates
    sudo apt update && sudo apt dist-upgrade
  3. Create a new file
    sudo gedit /usr/share/X11/xorg.conf.d/20-intel.conf
    and paste the following
    Section "Device"
            Identifier  "card0"
            Driver      "intel"
            Option      "Backlight"  "intel_backlight"
            Option      "AccelMethod" "sna"
            Option      "TearFree" "true"
            Option      "DRI" "3"
            BusID       "PCI:0:2:0"
    EndSection
    Close and save the file
  4. Modify and update grub
    sudo gedit /etc/default/grub
    and set
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
    Then run:
    sudo update-grub
  5. Install indicator-brightness
    sudo add-apt-repository ppa:indicator-brightness/ppa
    sudo apt-get update
    sudo apt-get install indicator-brightness
  6. Create keyboardshortcut
    Setting > keyboard > shortcuts > Custom shortcuts > '+'`
    • Name: Up brightness
    • Command: /opt/extras.ubuntu.com/indicator-brightness/indicator-brightness-adjust --up
    and
    • Name: Down brightness
    • Command: /opt/extras.ubuntu.com/indicator-brightness/indicator-brightness-adjust --down
  7. Click on 'disable' to set the keyboard shortcut
muru
  • 207,228
I input:
sudo dpkg --configure -a
and then my brightness setting back to normal.
Stephen Rauch
  • 1,156
  • 15
