I’m trying to install Ubuntu 16.04 alongside with Windows 7. My HDD supports only 4 partitions. Three of the partitions are taken up by windows. The fourth one is labelled as free space.
Now, how do I make root, swap and home partitions? Should I format my free space as primary with EXT4 first (if so, what should be the mount point?) and then create logical partitions for root/Home/swap? How do I go about this?
Edit: I tried to use the automatic installation option for dual boot. However I got the error ubi partman exit code 141. Probably because it tried to create two separate partitions for root and swap.
$ sudo parted -l
Model: ATA ST1000DM003-1CH1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      1049kB  106MB  105MB  primary  ntfs         boot
 2      106MB   277GB  277GB  primary  ntfs
 3      277GB   903GB  627GB  primary  ntfs
heethesh
  • 133
In a new installation of Ubuntu 18.04 there is no need for either home or swap partitions and creating them is a waste of disk space. One ext4 partition for everything is all you need. This answer would also have helped you in Nov. 5, 2017 because starting in new installations of Ubuntu 17.04, the Ubuntu installer creates a swap file instead of a swap partition by default, so a single partition is all you need. The recommended size of this single partition is 25GB or larger, and the default format of this partition is ext4.
SSDs are currently so cheap that it makes sense to buy a >=256GB SSD and install Ubuntu in a single partition on the SSD. If the Ubuntu installation requires an additional 500MB EFI System Partition, then the Ubuntu installer will create one if it doesn't already exist.
karel
  • 122,292
  • 133
  • 301
  • 332
In addition to the @karel's answer, here is how to setup swap-file on the previous Ubuntu versions, as 16.04:
sudo fallocate -l 16G /swapfile # Create a 'swap-file'; 16G in this case
sudo chmod 600 /swapfile        # Set the necessary file permissions
ls -lh /swapfile                # Check
sudo mkswap /swapfile           # Mark the file as 'swap'
sudo swapon /swapfile           # Enable the 'swap'
sudo swapon --show              # Check
free -h                         # Another check
Edit /etc/fstab and make the changes permanent:
sed 's/^.*swap.*$//' /etc/fstab -i.bak # Remove the previous swap related entries
                                       # and create a backup copy of the file
echo '/swapfile none swap sw 0 0' | sudo tee -a /etc/fstab # Add a new entry
Or edit /etc/fstab and add the the following entry manually:
Ideas for additional tweaks (I would prefer to use the default settings for normal swap usage):
  • Change the frequency of RAM to SWAP data copy:
    sudo sysctl vm.swappiness=10    # value 0-100: low value low frequency
    cat /proc/sys/vm/swappiness     # Check
  • Change the frequency of Cache flush:
    sudo sysctl vm.vfs_cache_pressure=50 # 0-100: high value high frequency
    cat /proc/sys/vm/vfs_cache_pressure  # Check
  • Make the above changes permanent:
    sudo cp /etc/sysctl.conf{,.bak} # Create a backup copy of the file '/etc/sysctl.conf'
    echo -e '\nCustom settings: value 0-100; default 100\nvm.swappiness=10\nvm.vfs_cache_pressure=50' | sudo tee -a /etc/sysctl.conf
    Or edit /etc/sysctl.conf and add the the following entries manually:
    # Custom settings: value 0-100; default 100
    vm.swappiness=10
pa4080
  • 30,621
