I had a similar problem with brother printer/scanner MFC-J625DW.
Could not get the scanner to work until I followed the instructions on this faq. Second item, "I cannot find the brother machine". Apparently, some files may be copied into the wrong folder. My system is lubuntu 17.10 32-bit and the driver is brscan4.
According to the faq the fix is :
Check if the following directory exist.
For 64bit Users:
/usr/lib/x86_64-linux-gnu/sane
For 32bit Users:
/usr/lib/i386-linux-gnu/sane
Type the following command if the above directory exists.
For 64bit Users:
Command : sudo cp /usr/lib64/sane/libsane-brother* /usr/lib/x86_64-linux-gnu/sane
For 32bit Users:
Command : sudo cp /usr/lib/sane/libsane-brother* /usr/lib/i386-linux-gnu/sane
Next to this, your username must also be part of the group owning the scanning device. 'lp' in my case.
And if you want to start scanning from the device, you need to install and run first brscan-skey
To clarify I will list all actions I did to get my MFC-J625DW to work (reboot between some steps may be useful):
- download, unzip and run script for your device from
support.brother.com (this installed all necessary packages for my
device) Follow all instructions on that site.
- add myusername to the
group lp, owning the scan device
sudo adduser <myusername> lp
- if you need to find out the name of this group, switch on the device, do
lsusb, note the busnr and devicenr of the brother, and execute ls -l /dev/bus/usb/busnr/devicenr (3 digits per nr)
- did the filecopying fix described above
- to enable all features of brscan-skey, I need gimp, sane and xsane
sudo apt install gimp
sudo apt install sane sane-utils libsane-extras xsane
