I am using XUbuntu 18.04 and I am struggling to install my scanner. I have tried everything i have been able to find on both Brother homepage and AskUbuntu. I have newest brsaneconfig4, brscan-skey and rules.
Command brsaneconfig4 -q returns:
Devices on network
0 DCP-7055W           "DCP-7055W"         I:192.168.1.28
Command scanimage -L returns:
device `brother4:net1;dev0' is a Brother DCP-7055W DCP-7055W
While command brscan-skey -l returns:
DCP-7055W         : brother4:net1;dev0  : 192.168.1.28         Not responded
I have libsane-brother4.so installed in /usr/lib64/sane, /usr/lib/sane and /usr/lib/x86_64-linux-gnu/sane
Command dpkg -l | grep Brother returns:
ii  brother-udev-rule-type1               1.0.2                               all          Brother udev rule type 1
ii  brscan-skey                           0.2.4-1                             amd64        Brother Linux scanner S-KEY tool
ii  brscan4                               0.4.6-1                             amd64        Brother Scanner Driver
ii  dcp7055wcupswrapper:i386              3.0.1-1                             i386         Brother DCP-7055W CUPS wrapper driver
ii  dcp7055wlpr:i386                      3.0.1-1                             i386         Brother DCP-7055W LPR driver
ii  printer-driver-brlaser                4-1                                 amd64        printer driver for (some) Brother laser printers
ii  printer-driver-ptouch                 1.4.2-3                             amd64        printer driver Brother P-touch label printers
and my libsane file has following content:
#   udev rules
ACTION!="add", GOTO="brother_mfp_end"
SUBSYSTEM=="usb", GOTO="brother_mfp_udev_1"
SUBSYSTEM!="usb_device", GOTO="brother_mfp_end"
LABEL="brother_mfp_udev_1"
SYSFS{idVendor}=="04f9", GOTO="brother_mfp_udev_2"
ATTRS{idVendor}=="04f9", GOTO="brother_mfp_udev_2"
LABEL="brother_mfp_udev_2"
ATTRS{bInterfaceClass}!="0ff", GOTO="brother_mfp_end"
ATTRS{bInterfaceSubClass}!="0ff", GOTO="brother_mfp_end"
ATTRS{bInterfaceProtocol}!="0ff", GOTO="brother_mfp_end"
#MODE="0666"
#GROUP="scanner"
ENV{libsane_matched}="yes"
#SYMLINK+="scanner-%k"
LABEL="brother_mfp_end"
I have tried everything without any significant success. At some point I have had working scanner, but after reboot it was no longer visible in SimpleScan. How can i make this work? What is missing?
I came across the posting Brother MFC-L2700DW printer can print, can’t scan by oscar1919 on Ask Ubuntu. I have a Brother multi-function printer but a different model than that specified by Oscar.
Oscar indicated that some of the installation files may be copied into the wrong folder. For 64-bit Linux, the instructions were to check that the folder /usr/lib/x86_64-linux-gnu/sane exists.
However, In my case, this folder was indeed present, but it was empty. The subsequent instructions were, essentially to copy the files libsane-brother* from the /usr/lib64/sane/ folder to /usr/lib/x86_64-linux-gnu/sane.
On my system, the three files to be copied were: libsane-brother2.so, libsane-brother2.so.1 and libsane-brother2.so.1.0.7.
Once these files were located in the /usr/lib/x86_64-linux-gnu/sane folder, Simple Scan sprung to life and scanned a test document.
CentaurusA
  • 2,692
Additional answer here which works on every Ubuntu version so far.
On brother website, there's a package that does that's called "Driver install tool".
  1. download it
  2. run in terminal
  3. provide your model by typing it's name i.e: DCP-9015CDW
follow the installer to also install a scanner drivers after printer is done. After the installer is done, simplescan will pick the scanner up without reboot.
The only "catch" is: if you want to install it over WiFi, make sure your printer has a static IP assigned on your router, and use that IP during install (one of the options is to provide the installer with the IP of the machine). If the IP of the driver changes, there's a chance you will have to redo your brsaneconfig everytime that happens so it's better to assign static IP to the printer/scanner.
Had no issues since.
Example download page for DCP-9015CDW: https://support.brother.com/g/b/downloadlist.aspx?c=gb&lang=en&prod=dcp9015cdw_eu&os=128 (listed under "Utilities" section)
Jan Myszkier
  • 1,273
Adding your username to the group that owns the scanner, lp in my case, may also be needed.
sudo adduser $USER lp.
oscar1919
  • 1,747
  • 14
  • 15
