I have just purchased a Brother MFC-L2700DW and cannot seem to install it; it doesn't appear in the list of Brother Printers in Ubuntu 12.04. Does anyone know if this printer is actually supported?
Fern Moss
  • 8,925
kv1948
Ironically a friend of more than 20 years emailed me today with the same question about a similar model of Brother Printer, and I can vouch that he is using version 12.04LTS, because I'm the one who installed it for him. I was able to save considerable typing by merely editing my reply to suit your model of Brother printer:
Driver installation tutorial for Brother MFC-L2700DW
  1. Open this link. http://support.brother.com/g/b/downloadtop.aspx?c=eu_ot&lang=en&prod=mfcl2700dw_us_eu_as
  2. Be sure to check (DEB not RPM). Ubuntu is Debian based, so downloading the RPM version will only lead to frustration.
  3. With Linux and linux(deb) checked, press SEARCH.
  4. The following page lists several choices, the first one being the most comprehensive.
  5. I recommend you download that first choice, the driver installer, and open it as soon as it has downloaded. Doing so will open your Ubuntu Software Center and complete the software installation.
It should work immediately without rebooting, but in case of difficulty, reboot.
gyropyge
  • 2,568
Test this:
Download this files:
http://download.brother.com/welcome/dlf101791/mfcl2700dwlpr-3.2.0-1.i386.deb
http://download.brother.com/welcome/dlf101792/mfcl2700dwcupswrapper-3.2.0-1.i386.deb
Install the drivers:
Turn on the printer and connect the usb, network or parallel cable.
Go to the directory where the drivers are.
In a terminal
Press Ctrl+Alt+T
run:
sudo -i
dpkg -i --force-all mfcl2700dwlpr-3.2.0-1.i386.deb
dpkg -i --force-all mfcl2700dwcupswrapper-3.2.0-1.i386.deb
Depending on the connection type you are using USB or Network, follow one of the steps below.
For USB Connection:
Open a web browser and go to "http://localhost:631/printers".
Check if the Device URI of your printer is "usb://Brother/(your printer's model name)"
If the device URI is different from the example above, please go to "Modify Printer" of your printer to select proper device and driver.
If your printer is not listed on "http://localhost:631/printers", please go to "http://localhost:631/admin" and click "Add printer" and select proper device and driver.
For Network Connection:
Click "Modify Printer" and set following parameters.
"LPD/LPR Host or Printer" or "AppSocket/HP JetDirect"       for Device
lpd://(Your printer's IP address)/binary_p1                 for Device URI
Brother                         for Make/Manufacturer Selection
Your printer's name             for Model/Driver Selection
For Scanner driver 32bit:
http://download.brother.com/welcome/dlf006646/brscan4-0.4.3-0.i386.deb
http://download.brother.com/welcome/dlf006651/brscan-skey-0.2.4-1.i386.deb
http://download.brother.com/welcome/dlf006654/brother-udev-rule-type1-1.0.0-1.all.deb
In a terminal
Press Ctrl+Alt+T
run:
sudo -i
dpkg -i --force-all brscan4-0.4.3-0.i386.deb
dpkg -i --force-all brscan-skey-0.2.4-1.i386.deb
dpkg -i brother-udev-rule-type1-1.0.0-1.all.deb
For Scanner driver 64 bit:
http://download.brother.com/welcome/dlf006645/brscan4-0.4.3-0.amd64.deb
http://download.brother.com/welcome/dlf006652/brscan-skey-0.2.4-1.amd64.deb
In a terminal
Press Ctrl+Alt+T
run:
sudo -i
dpkg -i --force-all brscan4-0.4.3-0.amd64.deb
dpkg -i --force-all brscan-skey-0.2.4-1.amd64.deb
For Network Connection to Scanner:
run:
brsaneconfig4 -a name=Brother model=MFCL2700DW ip=xx.xx.xx.xx
kyodake
  • 17,808
This works for me to recognize the printer
https://faithtechlife.com/2015/06/03/setting-up-brother-mfc-l2700dw-on-ubuntu/
I have tried xsane but somehow it could not find the printer. I must have done something wrong.
But the printing job works fine
