I cannot seem to upgrade from 11.04 to Oneiric because:
Error during update
A problem occurred during the update. This is usually some sort of
network problem, please check your network connection and retry.
W:Failed to fetch http://security.ubuntu.com/ubuntu/dists/oneiric-security/multivers/binary-amd64/Packages
404 Not Found [IP: 91.189.92.167 80], W:Failed to fetch
gzip:/var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_oneiric-security_main_binary-i386_Packages
Hash Sum mismatch, W:Failed to fetch
gzip:/var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_oneiric-security_universe_binary-i386_Packages
Hash Sum mismatch, E:Some index files failed to download. They have been ignored, or
old ones used instead.
Now I thought I would check my network connection despite the fact that it could find every other package and it ofc returned that my network was fine. So I decided to ping the IP of this package location myself (91.189.92.167) and got:
PING 91.189.92.167 (91.189.92.167) 56(84) bytes of data.
64 bytes from 91.189.92.167: icmp_req=1 ttl=128 time=40.5 ms
64 bytes from 91.189.92.167: icmp_req=2 ttl=128 time=39.6 ms
64 bytes from 91.189.92.167: icmp_req=3 ttl=128 time=41.0 ms
64 bytes from 91.189.92.167: icmp_req=4 ttl=128 time=38.7 ms
64 bytes from 91.189.92.167: icmp_req=5 ttl=128 time=41.1 ms
64 bytes from 91.189.92.167: icmp_req=6 ttl=128 time=38.6 ms
--- 91.189.92.167 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5009ms
rtt min/avg/max/mdev = 38.658/39.967/41.195/1.038 ms
Which meant everything was dandy on that side. So I thought maybe the host cannot be resolved so I did host -v:
sam@ubuntu:~$ host -v security.ubuntu.com
Trying "security.ubuntu.com"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 30243
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;security.ubuntu.com.           IN      A
;; ANSWER SECTION:
security.ubuntu.com.    5       IN      A       91.189.92.167
security.ubuntu.com.    5       IN      A       91.189.92.166
Received 69 bytes from 192.168.153.2#53 in 37 ms
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 42468
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;security.ubuntu.com.           IN      AAAA
;; AUTHORITY SECTION:
ubuntu.com.             5       IN      SOA     ns1.canonical.com.hostmaster.ca     nonical.com. 2012011402 10800 3600 604800 3600
Received 98 bytes from 192.168.153.2#53 in 39 ms
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 23755
;security.ubuntu.com.           IN      MX
Received 98 bytes from 192.168.153.2#53 in 40 ms
Which again looks just dandy so I am stuck with thinking that for some reason it has to be something with:
So I did a little searching and found a problem with ppa repos: Update Manager Refuses to Update
But the thing is I am not using ppa so that cant be my problem.
Does anyone know what else could be stopping me from upgrading my Ubuntu?
Maybe I am overlooking something that is right in front my eyes and its just past my bed time, either way I am totally stumped.
Thanks,
EDIT: Also when I try and do a sudo apt-get update now I get:
Err http://security.ubuntu.com oneiric-security/multiverse amd64 Packages
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/oneiric-security/multiverse/binary-amd64/Packages  404  Not Found [IP: 91.189.92.167 80]
E: Some index files failed to download. They have been ignored, or old ones used     instead.
Sammaye
  • 125
You have a typo in your sources.list (multivers instead of multiverse for oneiric-security repository) which causes the 404 Not Found error
For those two Hash Sum mismatch errors: Remove the files in /var/lib/apt/lists/partial/ and try to update again.
If you still get this error download http://security.ubuntu.com/ubuntu/dists/oneiric-security/main/binary-i386/Packages.gz, calculate the MD5 checksum and compare it with the one in http://security.ubuntu.com/ubuntu/dists/oneiric-security/Release
Do they match?
