I'm actually trying to upgrade my Ubuntu 11.04 server to 12.04, but I have to go through 11.10 first, right? Well, do-release-upgrade is failing miserably. Here is the output, with duplicate lines and such removed (still > 1500 lines): http://paste.ubuntu.com/1018546/
Yeah. I found this question, which seems to mention similar errors, but I've tried all of the suggestions given there and nothing has changed.
I tried running apt-get dist-upgrade; it churned for a while and eventually came back with "Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?" Ran apt-get update and got much the same kinds of error messages I got from do-release-upgrade.
The following are samples of the outputs that raise my eyebrow (line numbers reference the pastebin code):
Ign http://us.archive.ubuntu.com natty InRelease(e.g. line 43)--don't know if this is a problem or not, but it shows up frequentlyErr http://security.ubuntu.com natty-security/restricted amd64 Packages(e.g. line 101)bzip2: (stdin) is not a bzip2 file.(e.g. line 117)404 Not Found [IP: 91.189.92.167 80](e.g. line 199)--when this occurs, it always occurs after one of theErrlinesUpdating repository information WARNING: Failed to read mirror file(e.g. lines 580-81)E.g. lines 1045-52:
bzip2: Data integrity error when decompressing. Input file = (stdin), output file = (stdout) It is possible that the compressed file(s) have become corrupted. You can use the -tvv option to test integrity of such files. You can use the `bzip2recover' program to attempt to recover data from undamaged sections of corrupted files.
And the summary of the whole train wreck can be found in lines 1520-65.
Any ideas/suggestions/solutions? (The bzip2 errors particularly confuse me. It looks like it's trying to decompress from stdin? Is it supposed to do that?) Should I try downloading & upgrading from the ISO instead? (Edit: ISO upgrade failed too.) I'm glad to provide any further information I've forgotten. TIA!
