28
[Update] I'm able to install the 375 drivers fine using
sudo apt-get install nvidia-375
but the issue below still persists with 381.[/Update]
So last night I decided to update my nvidia drivers to 381 following some steps I found online. Here are the steps I followed:
sudo apt-get purge nvidia*
sudo add-apt-repository ppa:graphics-drivers
sudo apt-get update
sudo apt-get install nvidia-381
Whenever I get to "sudo apt-get install nvidia-381" command I receive "Unable to locate package nvidia-381"
I've searched everywhere and can't find a solution this. Any ideas?
Here is my output:
tyler@tyler-ubuntu:~$ sudo add-apt-repository ppa:graphics-drivers/ppa
 Fresh drivers from upstream, currently shipping Nvidia.
## Current Status
Current official release: `nvidia-381` (381.22)
Current long-lived branch release: `nvidia-375` (375.66)
For G8x, G9x and GT2xx GPUs use `nvidia-340` (340.102)
For NV4x and G7x GPUs use `nvidia-304` (304.135)
Support timeframes for Unix legacy GPU releases:
https://nvidia.custhelp.com/app/answers/detail/a_id/3142
## What we're working on right now:
- Normal driver updates
- Help Wanted: Mesa Updates for Intel/AMD users, ping us if you want to help do this work, we're shorthanded.
## WARNINGS:
This PPA is currently in testing, you should be experienced with packaging before you dive in here:
Volunteers welcome! See also: https://github.com/mamarley/nvidia-graphics-drivers/
### How you can help:
## Install PTS and benchmark your gear:
    sudo apt-get install phoronix-test-suite
Run the benchmark:
    phoronix-test-suite default-benchmark openarena xonotic tesseract gputest unigine-valley
and then say yes when it asks you to submit your results to openbechmarking.org. Then grab a cup of coffee, it takes a bit for the benchmarks to run. Depending on the version of Ubuntu you're using it might preferable for you to grabs PTS from upstream directly: http://www.phoronix-test-suite.com/?k=downloads
## Share your results with the community:
Post a link to your results (or any other feedback to): https://launchpad.net/~graphics-drivers-testers
Remember to rerun and resubmit the benchmarks after driver upgrades, this will allow us to gather a bunch of data on performance that we can share with everybody.
If you run into old documentation referring to other PPAs, you can help us by consolidating references to this PPA.
If someone wants to go ahead and start prototyping on `software-properties-gtk` on what the GUI should look like, please start hacking!
## Help us Help You!
We use the donation funds to get the developers hardware to test and upload these drivers, please consider donating to the "community" slider on the donation page if you're loving this PPA:
http://www.ubuntu.com/download/desktop/contribute
 More info: https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
Press [ENTER] to continue or ctrl-c to cancel adding it
gpg: keybox '/tmp/tmpf35j9cfi/pubring.gpg' created
gpg: /tmp/tmpf35j9cfi/trustdb.gpg: trustdb created
gpg: key FCAE110B1118213C: public key "Launchpad PPA for Graphics Drivers Team" imported
gpg: Total number processed: 1
gpg:               imported: 1
OK
tyler@tyler-ubuntu:~$ sudo apt-get update
Hit:1 http://repo.steampowered.com/steam precise InRelease
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://packages.microsoft.com/repos/vscode stable InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu zesty InRelease
Hit:5 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu zesty InRelease
Hit:6 http://dl.google.com/linux/chrome/deb stable Release
Get:7 http://security.ubuntu.com/ubuntu zesty-security InRelease [89.2 kB]
Hit:8 http://us.archive.ubuntu.com/ubuntu zesty-updates InRelease
Get:9 http://us.archive.ubuntu.com/ubuntu zesty-backports InRelease [89.2 kB]
Hit:10 http://ppa.launchpad.net/noobslab/macbuntu/ubuntu zesty InRelease
Hit:11 http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu zesty InRelease
Fetched 178 kB in 0s (204 kB/s)
Reading package lists... Done
tyler@tyler-ubuntu:~$ sudo apt-get install nvidia-381
Building dependency tree
E: Unable to locate package nvidia-381
Additional outputs:
tyler@tyler-ubuntu:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=17.04
DISTRIB_CODENAME=zesty
DISTRIB_DESCRIPTION="Ubuntu 17.04"
tyler@tyler-ubuntu:~$ apt-cache policy nvidia-381
N: Unable to locate package nvidia-381
6 Answers6
64
Because this is a top listed return search on Google on the subject, I wanted to post this because it seems things have changed.
This won't work for me after a fresh Ubuntu Desktop 18.0.4 install:
sudo apt install nvidia-396
This will:
sudo apt install nvidia-driver-396
No idea why the syntax changed. Makes for a lot of information on installing Nvidia drivers on the web confusing. So much wasted time!
The second command is wrong. It should be:
Pilot6
  • 92,041
Problem solved.
When verifying my PPA's in Software & Updates > Other Software I noticed that the graphics-drivers PPA was listed SEVERAL times in the PPA list. I removed all of the PPA's related to graphics-drivers and started the install over from scratch and it finally located and installed the nvidia-381 drivers.
I'm not sure why the repository was listed so many times but none-the-less after removing and going through the install again it finally worked.
For GeForce 8 and 9 series GPUs use nvidia-340
For GeForce 6 and 7 series GPUs use nvidia-304
psukys
  • 3,670
The generic problem is that your current version of ubuntu doesn't have the driver you are looking for in its apt package manager (or the driver is named something different from what you expect).
To see the which drivers are available for your ubuntu version in the apt repository, go to packages.ubuntu.com and search for 'nvidia'. Then select your ubuntu version (xenial, bionic, focal, etc.), and it will show you which drivers are available for installation through apt.
If the nvidia-driver version that you want isn't there, then you can take your chances with installing the driver from the .run file provided on the nvidia website, but if your ubuntu version is too old compared to the nvidia-driver, you might run into issues.
Jacob Stern
  • 291
If you look at the ppa, the package is called "nvidia-graphics-drivers-381"
https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa/+packages
sudo apt-get install nvidia-graphics-drivers-381
Panther
  • 104,528
