I am having issues loading the NVIDIA driver on Ubuntu 21.04. The result of nvidia-smi is
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver.
Make sure that the latest NVIDIA driver is installed and running.
And the result of nvidia-settings:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
I have tried reinstalling the latest NVIDIA driver available, 470.57.02 (my current kernel is 5.14.2-051402-generic). When installing with sudo apt-get update and sudo apt-get install nvidia-driver-470 I get this error:
    INFO:Enable nvidia
    DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
    DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
    DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
    Loading new nvidia-470.57.02 DKMS files...
    Building for 5.14.2-051402-generic 5.14.3-051403-generic
    Building for architecture x86_64
    Building initial module for 5.14.2-051402-generic
    ERROR (dkms apport): kernel package linux-headers-5.14.2-051402-generic is not supported
    Error! Bad return status for module build on kernel: 5.14.2-051402-generic (x86_64)
    Consult /var/lib/dkms/nvidia/470.57.02/build/make.log for more information.
    dpkg: error processing package nvidia-dkms-470 (--configure):
     installed nvidia-dkms-470 package post-installation script subprocess returned error exit status 10
    dpkg: dependency problems prevent configuration of nvidia-driver-470:
     nvidia-driver-470 depends on nvidia-dkms-470 (= 470.57.02-0ubuntu1); however:
      Package nvidia-dkms-470 is not configured yet.
dpkg: error processing package nvidia-driver-470 (--configure):
 dependency problems - leaving unconfigured
Setting up libnvidia-encode-470:amd64 (470.57.02-0ubuntu1) ...
No apport report written because the error message indicates its a followup error from a previous failure.
        Processing triggers for desktop-file-utils (0.26-1ubuntu1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libc-bin (2.33-0ubuntu5) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for mailcap (3.68ubuntu1) ...
Processing triggers for initramfs-tools (0.139ubuntu3) ...
update-initramfs: Generating /boot/initrd.img-5.14.3-051403-generic
 nvidia-dkms-470
 nvidia-driver-470
I have tried purging all NVIDIA packages with sudo apt-get purge nvidia-*, sudo apt-get autoremove and repeating the process, but no success. I also tried installing it on a previous kernel (5.11), installing a previous driver (nvidia-driver-460), but nothing worked.
The card is correctly detected. This is the output of lspci | grep NVIDIA:
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 228e (rev a1)
I also have tried the solutions from Unable to install nvidia drivers - unable to locate package, and NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running, still no success.
Any advice? Thanks!
elperno
  • 39
I finally succeeded in fixing it. The problem was indeed related to Secure Boot. I already had it disabled, but along the way I had set the boot mode as UEFI with CSM instead of plain UEFI. That was causing trouble.
(The answer by w-sky at NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running gave me the hint)
So these are the steps that fixed my problem:
  • In Additional drivers, deactivate the NVIDIA driver by choosing x.org (nouveau) instead. Reboot.
  • Boot menu, select UEFI (not UEFI with CSM!!) and disable Secure Boot.
  • In Additional drivers, activate again NVIDIA driver and reboot again.
You can probably leave Secure Boot enabled. In that case, when setting the NVIDIA driver you'll be requested to enroll a new MOK key, and after rebooting you'll be asked to type it in again in order to grant hardware access to the driver. I did not do it in my case, as enabling Secure Boot also prevented iwlwifi drivers to access the AX210 wifi card in my laptop.
Good luck!
elperno
  • 39
