My problem:
I got this message when trying to install updates:
The upgrade needs a total of 176 M free space on disk '/boot'. Please free at least an additional 176 M of disk space on '/boot'. Empty your trash and remove temporary packages of former installations using 'sudo apt-get clean'.
About my System:
The result of cat /etc/fstab looke like this:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/ubuntu--vg-root / ext4 errors=remount-ro 0 1
# /boot was on /dev/nvme0n1p2 during installation
UUID=30d084a8-283a-4450-b101-c1c60819364a /boot ext2 defaults 0 2
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=B6F8-3AD2 /boot/efi vfat umask=0077 0 1
/dev/mapper/ubuntu--vg-swap_1 none swap sw 0 0
The result of df -h looks like this:
Filesystem Size Used Avail Use% Mounted on
udev 12G 0 12G 0% /dev
tmpfs 2,4G 9,8M 2,4G 1% /run
/dev/mapper/ubuntu--vg-root 894G 95G 754G 12% /
tmpfs 12G 439M 12G 4% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 12G 0 12G 0% /sys/fs/cgroup
/dev/nvme0n1p2 473M 465M 0 100% /boot
/dev/nvme0n1p1 511M 3,4M 508M 1% /boot/efi
cgmfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs 2,4G 88K 2,4G 1% /run/user/1000
Result of uname -a looks like this:
Linux ##### 4.8.0-58-generic #63~16.04.1-Ubuntu SMP Mon Jun 26 18:08:51 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Result of dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d' looks like this:
linux-headers-4.10.0-27
linux-headers-4.10.0-27-generic
linux-headers-4.4.0-78
linux-headers-4.4.0-78-generic-tuxonice
linux-headers-4.4.0-83
linux-headers-4.4.0-83-generic-tuxonice
linux-headers-4.8.0-36
linux-headers-4.8.0-36-generic
linux-headers-4.8.0-53
linux-headers-4.8.0-53-generic
linux-headers-4.8.0-54
linux-headers-4.8.0-54-generic
linux-headers-4.8.0-56
linux-headers-4.8.0-56-generic
linux-image-4.4.0-78-generic-tuxonice
linux-image-4.4.0-83-generic-tuxonice
linux-image-4.8.0-36-generic
linux-image-4.8.0-53-generic
linux-image-4.8.0-54-generic
linux-image-4.8.0-56-generic
linux-image-extra-4.4.0-78-generic-tuxonice
linux-image-extra-4.8.0-36-generic
linux-image-extra-4.8.0-53-generic
linux-image-extra-4.8.0-54-generic
linux-image-extra-4.8.0-56-generic
linux-libc-dev:amd64
linux-signed-image-4.8.0-53-generic
linux-signed-image-4.8.0-54-generic
linux-signed-image-4.8.0-56-generic
What I tried:
From posts like these, e.g.: How do I free up more space in /boot?
I assume, I can remove the following images:
with this command: sudo apt-get purge linux-image-4.8.0-{36,53,54}-generic
I now got the following questions:
- The result of
sudo apt-get purge linux-image-4.8.0-{36,53,54}-genericwas this:
Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: linux-image-extra-4.10.0-28-generic : Depends: linux-image-4.10.0-28-generic but it is not going to be installed linux-image-extra-4.8.0-36-generic : Depends: linux-image-4.8.0-36-generic but it is not going to be installed linux-image-extra-4.8.0-53-generic : Depends: linux-image-4.8.0-53-generic but it is not going to be installed linux-image-extra-4.8.0-54-generic : Depends: linux-image-4.8.0-54-generic but it is not going to be installed linux-image-generic-hwe-16.04 : Depends: linux-image-4.10.0-28-generic but it is not going to be installed linux-signed-image-4.10.0-28-generic : Depends: linux-image-4.10.0-28-generic (= 4.10.0-28.32~16.04.2) but it is not going to be installed linux-signed-image-4.8.0-53-generic : Depends: linux-image-4.8.0-53-generic (= 4.8.0-53.56~16.04.1) but it is not going to be installed linux-signed-image-4.8.0-54-generic : Depends: linux-image-4.8.0-54-generic (= 4.8.0-54.57~16.04.1) but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Why do I have to install something when I want to delete images? And how do I delete the images. As it looks like the images are still there after I typed in the command dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d'
- Do I also have to delete the files with
linux-headers-*andlinux-signed-image-*? For example if I deletelinux-image-4.8.0-36-generic, then I probably don't need
linux-headers-4.8.0-36 linux-headers-4.8.0-36-generic linux-image-extra-4.8.0-36-generic
Shouldn't Ubuntu handle the deletion of not needed kernels automatically or what is the reason I have to do it manually? I used ubuntu on a different machine before for a few years and never had to do this. Now I got a new machine and suddenly after a few months I'm facing with this issue.
I have to encrypt my hard drive. Could this be the reason?
UPDATE:
I ran these commands:
sudo apt-get -f installsudo apt-get cleansudo apt autoremove -f
but all resulted in the this error:
Unpacking linux-image-4.10.0-28-generic (4.10.0-28.32~16.04.2) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.10.0-28-generic_4.10.0-28.32~16.04.2_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.10.0-28-generic' to '/boot/System.map-4.10.0-28-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.10.0-28-generic /boot/vmlinuz-4.10.0-28-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.10.0-28-generic /boot/vmlinuz-4.10.0-28-generic
