14
How can I search for *.odt or *.doc files that contain certain text in Ubuntu?
I use grep -rl <text to search for>, but this only works for text files.
Note: a solution that uses grep (such as searchmonkey) will not work because the *.doc or *.odt files have a special format.
From How to search for strings inside files in a folder?
  • Recoll wants to index my home directory, but I want to search *.odt files in specific directories; I couldn't figure out how to do that with this tool.
  • Searchmonkey seems to be a GUI for grep, and as I mentioned, grep doesn't work on *.doc or *.odt files.
  • Regexxer also has the same problem.
From Searching through ODT documents without opening them?
  • Like Recoll, I couldn't figure out how to search *.odt files in specific directories with this tool.
Enterprise
  • 12,792
catdoc appears to work recursively for .doc files in 16.04: https://superuser.com/questions/330242/how-to-recursively-find-a-doc-file-that-contains-a-specific-word
There's no mention of .docx so you'll need to figure that one out yourself.
For .ods or .odt files, you could have the following script courtesy kaibob @ ubuntuforums.org:
#!/bin/bash
find . -type f -name ".od" | while read i ; do [ "$1" ] || { echo "You forgot search string!" ; exit 1 ; } unzip -ca "$i" 2>/dev/null | grep -iq "$*" if [ $? -eq 0 ] ; then echo "string found in $i" | nl fi done
Let's say you call it "libre-search" and have made it executable.
Then, running libre-search your_string should list files containing your_string. It will not list the string context.
unzip -ca "$i" 2>/dev/null takes care of unwanted content.
grep -iq makes the search case-insensitive.
nl numbers the output.
DK Bose
  • 44,553
