I've apt update'd from my sources.list, but the install fails because it apparently links to a non-existent package.
$ apt-cache policy apache2
apache2:
  Installed: (none)
  Candidate: 2.4.18-2ubuntu3.1
  Version table:
     2.4.18-2ubuntu3.1 500
        500 http://ports.ubuntu.com xenial-updates/main armhf Packages
        500 http://ports.ubuntu.com xenial-security/main armhf Packages
     2.4.18-2ubuntu3 500
        500 http://ports.ubuntu.com xenial/main armhf Packages
$ sudo apt-get install apache2 -y
After this operation, 4,889 kB of additional disk space will be used.
Ign:1 http://ports.ubuntu.com xenial-security/main armhf apache2-bin armhf 2.4.18-2ubuntu3.1
Ign:2 http://ports.ubuntu.com xenial-security/main armhf apache2-utils armhf 2.4.18-2ubuntu3.1
Ign:3 http://ports.ubuntu.com xenial-security/main armhf apache2-data all 2.4.18-2ubuntu3.1
Ign:4 http://ports.ubuntu.com xenial-security/main armhf apache2 armhf 2.4.18-2ubuntu3.1
Err:1 http://ports.ubuntu.com xenial-security/main armhf apache2-bin armhf 2.4.18-2ubuntu3.1
  404  Not Found [IP: 91.189.88.150 80]
Err:2 http://ports.ubuntu.com xenial-security/main armhf apache2-utils armhf 2.4.18-2ubuntu3.1
Err:3 http://ports.ubuntu.com xenial-security/main armhf apache2-data all 2.4.18-2ubuntu3.1
Err:4 http://ports.ubuntu.com xenial-security/main armhf apache2 armhf 2.4.18-2ubuntu3.1
E: Failed to fetch http://ports.ubuntu.com/pool/main/a/apache2/apache2-bin_2.4.18-2ubuntu3.1_armhf.deb  404  Not Found [IP: 91.189.88.150 80]
E: Failed to fetch http://ports.ubuntu.com/pool/main/a/apache2/apache2-utils_2.4.18-2ubuntu3.1_armhf.deb  404  Not Found [IP: 91.189.88.150 80]
E: Failed to fetch http://ports.ubuntu.com/pool/main/a/apache2/apache2-data_2.4.18-2ubuntu3.1_all.deb  404  Not Found [IP: 91.189.88.150 80]
E: Failed to fetch http://ports.ubuntu.com/pool/main/a/apache2/apache2_2.4.18-2ubuntu3.1_armhf.deb  404  Not Found [IP: 91.189.88.150 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
  • http://ports.ubuntu.com/pool/main/a/apache2/ lists apache2_2.4.18-2ubuntu3.3_armhf.deb but not apache2_2.4.18-2ubuntu3.1_armhf.deb (3.3 vs. 3.1). Is this an issue with the repo or my config?
  • For what it's worth, I didn't think the issue was a PPA-wide 404 as the repo exists but is missing the package. (I'm only using default ports.ubuntu.com sources (armhf), and xenial is not EOL, right? Unless just xenial-security has moved to old-releases: old-releases.ports.ubuntu.com?)
Wolf
  • 3,247
So I didn't figure out why my apt-get cache listed 2.4.18-2ubuntu3.1 when only ...ubuntu3.3 was available, but I did find that ...ubuntu3 (no decimal) installed just fine if I specified that version (or removed the other deb sources)
Wolf
  • 3,247
