41
They used to be in /usr/lib/X11/XKeysymDB or /usr/share/X11/XKeysymDB, but those have been missing from Ubuntu for a while. I've tried google, but all I get are more references to XKeysymDB or the outputs of different people's xmodmap -pke. Where is the concise list?
Dave E
  • 575
Probably the best up-to-date values for key symbol definitions is to look at the source-code.
Basically its just a list of keysym names with their associated codes.
sudo apt-get install x11proto-core-dev
Two key keyfiles in /usr/include/X11:
The main definition file:
/usr/include/X11/keysymdef.h
Vendor specific (i.e. Debian/Ubuntu):
/usr/include/X11/XF86keysym.h
There are a number of other header files in the same folder you can also examine:
$ grep -l '#define.*XK_' /usr/include/X11/*.h
Example definition from /usr/include/X11/keysymdef.h:
#define XK_BackSpace                     0xff08  /* Back space, back char */
#define XK_Tab                           0xff09
#define XK_Linefeed                      0xff0a  /* Linefeed, LF */
#define XK_Clear                         0xff0b
#define XK_Return                        0xff0d  /* Return, enter */
#define XK_Pause                         0xff13  /* Pause, hold */
#define XK_Scroll_Lock                   0xff14
#define XK_Sys_Req                       0xff15
#define XK_Escape                        0xff1b
#define XK_Delete                        0xffff  /* Delete, rubout */
Volker Siegel
  • 13,295
fossfreedom
  • 174,526
Note that if you want to learn the code for a specific key on your keyboard, you can use xev for X11 or wev for Wayland.
After starting xev/wev, you can press the key and see the X events printed to the terminal.
You can use xev | grep keysym/wev | grep keysym to filter the lines for the essential information. The keysym you need will be the second second argument in parenthesis.
