28
I can no longer boot Ubuntu following a corruption problem initially reported here (How do I solve the "invalid arch dependent elf magic" error message).
When I power my laptop, I now get the following message:
GNU GRUB version 2.02~beta2-9ubuntu1.7
Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions.
Anywhere else TAB lists possible device or file completions." and then the prompt
grub>
Can anyone help me get back to Ubuntu ?
Mons
  • 279
Ok, from grub type ls (hd0,1)/
you should see a file named vmlinuz or linux, and initrd.img
Type linux (hd0,1)/vmlinuz root=/dev/sda1 or linux (hd0,1)/linux root=/dev/sda1 depending on what you found with ls (hd0,1)/, then:
initrd (hd0,1)/initrd.img
boot
If you get initramfs rescue mode enter your password, then startx. You should now have a desktop.
Use gparted to check your file system, if it reports an error, then you need to boot from a LiveCD or other media to fix it .... DO NOT attempt to repair a mounted partition.
The following three commands fix many grub boot problems. They run quick so just do all three instead of trying to find which one you need.
sudo grub-install /dev/sda && sudo update-grub && sudo update-initramfs -u
Reboot and see what you get.
ravery
  • 6,924
The most probable cause to that issue is installing the OS to a disk, grub to a different disk that is not removable. Then removing the OS disk.
You could just plug the USB stick back in. Problem solved.
RobotHumans
  • 30,112
Restart your system. Press f2 key while loading. Goto boot option. Press f5/f6 to change values (which os you want to install keep it in first place.). Enter f10 key....It may solve your problem. . . . If not enter this in grub rescue mode.... ls (hd0) (hd0,msdos6) (hd0,msdos5)....(hd0,msdos1) OR (hd0) (hd0,gpt6).....(hd0,gpt1)
set boot=(hd0,gpt6) OR set boot=(hd0,msdos6) set prefix=(hd0,gpt6)/boot/grub OR use msdos6 instead. insmod normal normal This may solve your problem.
