I am trying to install 16.04LTS on an Asus X554L laptop. It previously had Windows 10, which became corrupted, and I had no desire to repair or reinstall Windows, and since I had been using Linux for almost 10 years now I decided to install Ubuntu on it (I also tried Debian). The installation can only be booted through UEFI, and it usually runs fine at first, but near the end it tells me that the installation of GRUB signed keys has failed.
Options for Secure Boot, CSM, and boot override within BIOS have been locked out of the user's ability to edit. Secure Boot is enabled, and CSM is disabled. I am still able to boot the Ubuntu installer (not Debian), however the computer refuses to boot the OS after it is installed. The only related option I am able to edit is insert or delete "Secure boot variables" which are the proprietary keys Ubuntu is lacking to install GRUB onto MBR.
Deleting all secure boot keys prevents the comptuer from booting the installers kernel, it just drops at the grub console
Nick Bailuc
  • 3,335
It sounds to that grub update failed not the signed kernels.
I have noticed that the file that adds the efi-firmware option to the grub menu errors on some computers. grub installs but the initial grub-update to create the config file is what fails.
the file /etc/grubd/30_efi-firmware needs to be edited to remove the if/then statement. then update grub.
I've edited mine to read:
gettext_printf "Adding boot menu entry for EFI firmware configuration\n" >&2
cat << EOF
menuentry 'uefi-firmware' {
fwsetup
EOF
if your installer has a command prompt at the bottom. you can make this change and reinstall grub (nano is the text editor. you may have to comment out the gettext_printf line also ).
if not then, continue with out installing grub, and make the change from a LiveCD. and update grub.
ravery
  • 6,924
