I am not exactly a newbie linux user (I use mostly debian based distros for years) but I have to ask because it is a complicated question.
I have an external hard drive and I want to use it with the best way I can imagine:
  1. It has to contain the needed partitions to be used as a live usb with enough persistent space for useful packages. I will use the way I found here (I hope this way I will have the option to install ubuntu to other PCs with the help of my external drive and to run ubuntu in any PC)->see Edit bellow
  2. I would like to have some (the most) of the space of my external drive for backups and for any useful file I want to save and to carry. (I want this partition ntfs or fat32 to can view my files from any OS -but I am open to discuss it-)
  3. I would like to use this disk as a backup-restore disk for my windows and so I need an ntfs partition for that because windows doesn't allow other kind of filesystem for this job.
  4. Any other usefull partition like swap or bios-grub or efi that needed to have access from every PC to my files and to my live ubuntu
My question is: How can I proceed to make this happen?
Step by step please (include links where needed and detailed answer including the kind of partition table that would be better etc)
PS: I tried to make it featured question and give some points but probably I am too new to the "forum" :(
Edit: Finally after a discussion with @sudodus and the comments of the others, I decided that the live OS functionality of the external HD costs more and offers less than I expected... I tested the functionality of live usb with persistent storage and I found out that windows complains with many of the partitions until finding the last one that can be used as storage... This is not good for a storage device (and that functionality of an external drive is more important)... Additionally... the drive will be much slower than a flash drive and this makes me to decide to use my HD as storage device... The other expectations remaining and I am close to decide to make a Gpt partitioning and have ntfs for windows restore files... ext4 for files I can acces from everywhere and may be one or more ext4 (if i find a reason for this)
koleygr
  • 177
You're asking for a lot, and some of it's unique to your specific needs and desires. Thus, you may not find an exact match to those needs, and asking for step-by-step instructions to meet those needs is unreasonable -- the time demands to create and test a procedure are too great on those of us who answer questions here. (We aren't paid to do this, you know!) That said, perhaps one or more of the following procedures will get you close to what you want:
Some specific issues you may encounter that might not be addressed by the preceding questions include:
  • BIOS vs. EFI -- A transition in firmware from BIOS to EFI/UEFI began quite a few years ago, but late 2011 was a tipping point. At that point, most manufacturers discontinued most of their pure-BIOS systems in favor of EFI-based systems. Most EFI-based computers include a feature called the Compatibility Support Module (CSM), which enables them to boot older OSes intended for BIOS-based computers; but the CSM might or might not be active. Thus, to support any x86-64 computer, the boot medium must provide both BIOS-mode and EFI-mode boot loaders. This is possible, but most instructions address installing just one boot loader. If you're willing to support just one boot mode, then the task becomes simpler, but you must ensure that the instructions you follow cover the mode you want to use.
  • Windows access -- Windows treats removable USB flash drives as "superfloppies," which means that it can access only the first partition on the disk. Thus, if you want to use the disk as a Windows backup medium, you must ensure that there's just one Windows-accessible medium and that it be the first one on the disk. All other partitions, including partitions that Windows could never use, must come after this first partition.
Rod Smith
  • 45,120
  • 66
  • 108
Dialogue
After a dialogue in this chat room, you are deciding how to configure and use your external hard disk drive. It is a good idea to ask and test before deciding and doing things.
I was suggesting that you use mkusb to make the external hard disk drive a persistent live drive (with a big NTFS partition for sharing data with computers running Windows).
Separate drives for storage and live boot
But you found that it is better to separate the function 'storage' and the function 'boot live' (or maybe 'boot persistent live'). An important reason is that you don't like that Windows complains about the partitions, that it does not recognize in the persistent live drive and suggests to format them. You see a potential risk that someone will let Windows damage the external hard disk drive or the data stored in the drive. In general, using the drive only for storage will reduce the risk to damage the data.
  • So the external hard disk drive will be partitioned for storage with a GUID partition table (GPT) and the first partition will be formatted with NTFS for sharing data between Ubuntu and Windows. You may add other partitions to be used by Ubuntu. Edit: A second partition will be formatted with FAT32, which is recognized by 'all' operating systems (including MacOS).
  • You intend to use a USB pendrive for booting a live (or persistent live) system with Ubuntu, probably the community flavour Ubuntu MATE.
sudodus
  • 47,684
It's actually very simple.
  1. I recommend you to shrink atleast 8gb from your internal hard drive for safety sakes.
  2. Burn your ubuntu iso to a usb hard drive.
  3. Insert your external hard drive(make sure it's empty)
  4. Boot from your usb
  5. Go through the install process until you see the choose where to install screen. (you'll see 4 selections)
  6. Click "Custom Install"
  7. Choose your external hard disk and format it by clicking the "-" button and then pressing the "+" button.
  8. Make sure you set your root folder to be / and then install ubuntu onto your external hard disk. (I'm not sure if you need a swap area)
  9. Reboot and in your bios settings change boot order so that your external hard drive will boot first. So if your external hdd is inserted, it'll boot ubuntu and if not inserted, it'll be windows or your other os.
  10. Then, go back to windows, and extend the main drive(because we shrank it at the start)
Jason
