Good day, AskUbuntu! As the title implies, I would like to know if it's possible to subscribe and receive data from a terminal running from another Ubuntu desktop, and how one would go about doing so.
I tried to look around for the answer prior, but I only seem to find remote desktop queries, which I don't believe is what I'm looking for. I don't mean to control a desktop using another or transfer files, but rather, use the published data from one's terminal to another.
If it's worth mentioning, my application is to have a Raspberry Pi 3 running Ubuntu MATE transmit sensory data (specifically my Kinect v2) to my laptop running Ubuntu 16.04 for processing (specifically using the Kinect's input to create a 3D map). Unfortunately, the RPi3 lacks the processing power to compile my programs (using ROS, but that's a different story) as well as generate a 3D map, so I need a separate and more powerful machine to do so. The reason why I can't just use my laptop directly is because I am using it on a mobile platform with wheels, and can't fully support the weight of it.
TL;DR - Is there a way to subscribe to a node from another machine and process its data in another?
Thank you, and good day.
You can just use netcat to both send and receive TCP packets:
Server
echo "hello" | netcat [client-ip-address] [port]
Client
netcat [server-ip-address] [port]
I would install openssh-server in the Raspberry Pi 3 (in Ubuntu MATE).
You can use ssh, sftp, rsync and several other tools to access the data from another computer via ssh, when you run openssh-server in the Raspberry Pi 3. I am happy with command line tools, but it is also possible to use tools with a graphical user interface.
See these links for more details,
help.ubuntu.com/14.04/serverguide/openssh-server.html
askubuntu.com/questions/897301/filezilla-crashes-ubuntu-16-04-lts-please-suggest-alternate
askubuntu.com/questions/886313/what-is-the-simplest-way-to-have-remote-gui-access-to-ubuntu-16-04-server-from/886398#886398
sudodus
  • 47,684
