Suddenly filezilla has started behaving abnormally.. As and when i try to connect to some ftp from the site manager , filezilla crashes and automatically closes..
If I try to connect via quick connect then it connects to the ftp but doesn't show any file or directory..
I am really struck here . my speed of working has been halved . I tried using gftp but its not as convenient as filezilla.
Please help me out with filezilla or suggest me an equivalent ftp client
I use the basic ssh and sftp because I learned how to use them long ago, and I find them easy to use.
But you may find it easier to use the standard file browser 'Files' alias nautilus in standard Ubuntu. Click on the symbol with three horizontal lines and select 'Enter Location', and type the IP address. In a local network you can type
sftp://192.168.0.2
if that is the address to your server. If you open another window with 'Files' you can copy between the windows (if you have write access).
You can create a bookmark if you intend to connect to this address again. Click on the symbol with three horizontal lines and select 'Bookmark this location'.
In case you are using a custom port e.g. 1234 and want to connect directly to a specific remote directory e.g. /var/www/example.com with the username someUser then type:
sftp://someUser@192.168.0.2:1234/var/www/example.com
If you have problems also with 'Files', I think there is some other problem, maybe with the network or with some tool under the hood, and not with Filezilla.
consuela
  • 363
sudodus
  • 47,684
Probably, it is a late reply though I faced the similar issue with FileZilla. Following steps resolved it for me.
  1. In the site manager, choose your site and on the right hand side, choose logon type as key file
  2. Give path of your .pem file. (You need to choose all files to see .pem file)
  3. You would get a prompt. choose to continue/ok.
And you are good to go. It will not crash any further and will connect to your server.
Note: In the edit -> settings -> SFTP, I have added my .pem file as well. Not sure if it is required now after using above two steps but it is there.
Regards,
