I followed this tutorial to set the brightness indicator on Unity. But when I run the
sudo /opt/indicator-brightness/indicator-brightness.py
command from a terminal, I get
(indicator-brightness.py:1734): Gtk-WARNING **: Impossible to find the theme engine in module_path : « pixmap »
Traceback (most recent call last):
  File "/opt/indicator-brightness/indicator-brightness.py", line 78, in <module>
    create_menu(ind)
  File "/opt/indicator-brightness/indicator-brightness.py", line 46, in create_menu
    curr_brightness = get_curr_brightness()
  File "/opt/indicator-brightness/indicator-brightness.py", line 33, in get_curr_brightness
    curr_brightness = int(p.communicate()[0])
ValueError: invalid literal for int() with base 10: 'No backlights were found on your system\n'
Any suggestion is most welcome.
Jorge Castro
  • 73,717
That tutorial links to some random deb on the internet (you shouldn't trust posts like that), so it's likely that deb is out of date.
Instead try installing it from the developer's PPA and see if you get the error still. If you still do then you need to file a bug on that page with the brightness-indicator developers so they can see if it's a code problem.
Jorge Castro
  • 73,717
This command works for me. I'm too lazy to install things. Hope this helps.
sudo setpci -s 00:02.0 F4.B=50
Eliah Kagan
  • 119,640
dsaint
  • 774
