I just upgraded Ubuntu from 14.04 to 16.04 which seems to have broken ZFS. I followed the directions here and purged all old ZFS packages. I then installed zfsutils-linux from the default 16.04 PPAs but whenever I run any ZFS commands I get the following error:
:~$ sudo zfs get all
The ZFS modules are not loaded.
Try running '/sbin/modprobe zfs' as root to load them.
I've attempted using modprobe as the error messages recommends:
:~$ sudo /sbin/modprobe zfs
modprobe: ERROR: could not insert 'zfs': Invalid argument
It seems like ZFS is not installed but apt-get shows that it is:
:~$ sudo apt-get install zfsutils-linux
Reading package lists... Done
Building dependency tree
zfsutils-linux is already the newest version (0.6.5.6-0ubuntu16).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
N: Ignoring file '50unattended-upgrades.ucf-dist' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension
I also physically went to my machine rather than using SSH to watch the boot and saw a number of ZFS items FAIL on startup, one of which I believe said something about dependencies, but it went by too fast for me to read all of them. I attempted to see what they say by looking in boot logs, but I've been unable to find a boot log file that matches the output shown during startup. Where can I look to see what is actually failing at startup?
Further interesting discovery is that if I use just the zfs command, I get the 'missing command' output, but when adding any command I get the same error message from above.
:~$ zfs
missing command
usage: zfs command args ...
where 'command' is one of the following:
create [-p] [-o property=value] ... <filesystem>
create [-ps] [-b blocksize] [-o property=value] ... -V <size> <volume>
destroy [-fnpRrv] <filesystem|volume>
destroy [-dnpRrv] <filesystem|volume>@<snap>[%<snap>][,...]
destroy <filesystem|volume>#<bookmark>
snapshot|snap [-r] [-o property=value] ... <filesystem|volume>@<snap> .. .
rollback [-rRf] <snapshot>
clone [-p] [-o property=value] ... <snapshot> <filesystem|volume>
promote <clone-filesystem>
rename [-f] <filesystem|volume|snapshot> <filesystem|volume|snapshot>
rename [-f] -p <filesystem|volume> <filesystem|volume>
rename -r <snapshot> <snapshot>
bookmark <snapshot> <bookmark>
list [-Hp] [-r|-d max] [-o property[,...]] [-s property]...
[-S property]... [-t type[,...]] [filesystem|volume|snapshot] ...
set <property=value> <filesystem|volume|snapshot> ...
get [-rHp] [-d max] [-o "all" | field[,...]]
[-t type[,...]] [-s source[,...]]
<"all" | property[,...]> [filesystem|volume|snapshot] ...
inherit [-rS] <property> <filesystem|volume|snapshot> ...
upgrade [-v]
upgrade [-r] [-V version] <-a | filesystem ...>
userspace [-Hinp] [-o field[,...]] [-s field] ...
[-S field] ... [-t type[,...]] <filesystem|snapshot>
groupspace [-Hinp] [-o field[,...]] [-s field] ...
mount
mount [-vO] [-o opts] <-a | filesystem>
unmount [-f] <-a | filesystem|mountpoint>
share <-a | filesystem>
unshare <-a | filesystem|mountpoint>
send [-DnPpRvLe] [-[iI] snapshot] <snapshot>
send [-Le] [-i snapshot|bookmark] <filesystem|volume|snapshot>
receive [-vnFu] <filesystem|volume|snapshot>
receive [-vnFu] [-d | -e] <filesystem>
allow <filesystem|volume>
allow [-ldug] <"everyone"|user|group>[,...] <perm|@setname>[,...]
<filesystem|volume>
allow [-ld] -e <perm|@setname>[,...] <filesystem|volume>
allow -c <perm|@setname>[,...] <filesystem|volume>
allow -s @setname <perm|@setname>[,...] <filesystem|volume>
unallow [-rldug] <"everyone"|user|group>[,...]
[<perm|@setname>[,...]] <filesystem|volume>
unallow [-rld] -e [<perm|@setname>[,...]] <filesystem|volume>
unallow [-r] -c [<perm|@setname>[,...]] <filesystem|volume>
unallow [-r] -s @setname [<perm|@setname>[,...]] <filesystem|volume>
hold [-r] <tag> <snapshot> ...
holds [-r] <snapshot> ...
release [-r] <tag> <snapshot> ...
diff [-FHt] <snapshot> [snapshot|filesystem]
Each dataset is of the form: pool/[dataset/]*dataset[@name]
For the property list, run: zfs set|get
For the delegated permission list, run: zfs allow|unallow
What else can I do to troubleshoot this ZFS install?
