I have delayed the update of my file server from 14.04LTS which I did yesterday. That upgrade totally broke ZFS.
I have tried everything I found on this site, like:
I tried:
sudo add-apt-repository --remove ppa:zfs-native/stable
sudo apt clean
Then: apt-get install zfsutils-linux returns:
zfsutils-linux is already the newest version (0.6.5.6-0ubuntu28).
You might want to run 'apt-get -f install' to correct these:
 zfs-zed : Depends: libnvpair1linux but it is not going to be installed
           Depends: libzfs2linux but it is not going to be installed
 zfsutils-linux : Depends: libnvpair1linux but it is not going to be installed
                  Depends: libuutil1linux but it is not going to be installed
                  Depends: libzpool2linux but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).'
So I try
sudo apt-get -f install
And now I get:
After this operation, 1,775 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libuutil1linux amd64 0.6.5.6-0ubuntu28 [27.4 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libnvpair1linux amd64 0.6.5.6-0ubuntu28 [23.5 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libzpool2linux amd64 0.6.5.6-0ubuntu28 [384 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libzfs2linux amd64 0.6.5.6-0ubuntu28 [107 kB]
Fetched 542 kB in 0s (636 kB/s)
(Reading database ... 1279402 files and directories currently installed.)
Preparing to unpack .../libuutil1linux_0.6.5.6-0ubuntu28_amd64.deb ... Unpacking libuutil1linux (0.6.5.6-0ubuntu28) ...
dpkg: error processing archive /var/cache/apt/archives/libuutil1linux_0.6.5.6-0ubuntu28_amd64.deb (--unpack):
trying to overwrite '/lib/libuutil.so.1.0.1', which is also in package libuutil1 0.6.5.4-1~precise
Preparing to unpack .../libnvpair1linux_0.6.5.6-0ubuntu28_amd64.deb ...
Unpacking libnvpair1linux (0.6.5.6-0ubuntu28) ...
dpkg: error processing archive /var/cache/apt/archives/libnvpair1linux_0.6.5.6-0ubuntu28_amd64.deb (--unpack):
trying to overwrite '/lib/libnvpair.so.1.0.1', which is also in package libnvpair1 0.6.5.4-1~precise
Preparing to unpack .../libzpool2linux_0.6.5.6-0ubuntu28_amd64.deb ...
Unpacking libzpool2linux (0.6.5.6-0ubuntu28) ...
dpkg: error processing archive /var/cache/apt/archives/libzpool2linux_0.6.5.6-0ubuntu28_amd64.deb (--unpack):
trying to overwrite '/lib/libzpool.so.2.0.0', which is also in package libzpool2 0.6.5.4-1~precise
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack .../libzfs2linux_0.6.5.6-0ubuntu28_amd64.deb ...
Unpacking libzfs2linux (0.6.5.6-0ubuntu28) ...
dpkg: error processing archive /var/cache/apt/archives/libzfs2linux_0.6.5.6-0ubuntu28_amd64.deb (--unpack):
trying to overwrite '/lib/libzfs.so.2.0.0', which is also in package libzfs2 0.6.5.4-1~precise
No apport report written because MaxReports is reached already
Processing triggers for libc-bin (2.23-0ubuntu11.2) ...
Errors were encountered while processing: /var/cache/apt/archives/libuutil1linux_0.6.5.6-0ubuntu28_amd64.deb /var/cache/apt/archives/libnvpair1linux_0.6.5.6-0ubuntu28_amd64.deb /var/cache/apt/archives/libzpool2linux_0.6.5.6-0ubuntu28_amd64.deb /var/cache/apt/archives/libzfs2linux_0.6.5.6-0ubuntu28_amd64.deb
dpkg -l | grep -i "zfs"
rc libzfs1 0.6.2-1~precise amd64 Native ZFS filesystem library for Linux ii libzfs2 0.6.5.4-1~precise amd64 Native OpenZFS filesystem library for Linux rc libzpool1 0.6.2-1~precise amd64 Native ZFS pool library for Linux ii libzpool2 0.6.5.4-1~precise amd64 Native OpenZFS pool library for Linux rc ubuntu-zfs 8~precise amd64 Native ZFS filesystem metapackage for Ubuntu. rc zfs-auto-snapshot 1.0.8-0ubuntu1~precise1 all ZFS Automatic Snapshot Service ii zfs-dkms 0.6.5.6-0ubuntu28 amd64 Native OpenZFS filesystem kernel modules for Linux ii zfs-doc 0.6.5.6-0ubuntu28 all Native OpenZFS filesystem documentation and examples. iU zfs-zed 0.6.5.6-0ubuntu28 amd64 OpenZFS Event Daemon (zed) rc zfsutils 0.6.5.4-1~precise amd64 Native OpenZFS management utilities for Linux iU zfsutils-linux 0.6.5.6-0ubuntu28 amd64 Native OpenZFS management utilities for Linux
OK, some improvements, through a combination of dpkg, apt and apt-get commands I was able to remove the dependency errors.
NOW, the issue is something that has been documented but the solutions haven't helped me.
First I did this: reboot
apt clean
apt update
apt purge zfs*
apt-get remove spl dkms spl-dkms
apt-get autoremove
reboot
sudo apt-get install zfsutils-linux zfs-initramfs spl-dkms
(I added zfs-initramfs because it was suggested)
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  dkms libnvpair1linux libuutil1linux libzfs2linux libzpool2linux spl zfs-dkms zfs-doc zfs-zed
The following NEW packages will be installed:
  dkms libnvpair1linux libuutil1linux libzfs2linux libzpool2linux spl spl-dkms zfs-dkms zfs-doc zfs-initramfs zfs-zed zfsutils-linux
0 upgraded, 12 newly installed, 0 to remove and 109 not upgraded.
Need to get 2,456 kB of archives.
After this operation, 14.6 MB of additional disk space will be used.
I get an error:
ERROR (dkms apport): kernel package linux-headers-3.13.0-181-generic is not supported
Error! Bad return status for module build on kernel: 3.13.0-181-generic (x86_64)
Consult /var/lib/dkms/zfs/0.6.5.6/build/make.log for more information.
What do I do now? Do I have a kernel issue?
zuru
  • 31
I did have a kernel issue. I didn't realize that the updater didn't touch the kernel. When I updated to 4.+, all problems went away! Whew...
Zanna
  • 72,312
zuru
  • 31
