I have a storage server running Ubuntu Server 14.04 LTS. I have ubuntu-zfs installed on it and I already use ZFS as my files system for the stored data.
I am trying to look into what issues i might have trying to upgrade from 14.04 to 16.04. Here are some of my worries:
  1. Will the upgrade convert the ubuntu-zfs setup in 14.04 to the native ZFS in 16.04? I'm thinking that the safest way would be to export the pools uninstall ubuntu-zfs upgrade to 16.04 and then re-import the pools, but i would rather not go through the trouble if i don't have to.
  2. Will there be issues importing pools created with ubuntu-zfs in 16.04 with native ZFS?
Thanks
Iustin
  • 51
7 Answers7
I found the upgrade straightforward(ish) in my case of non-root ZFS, just needing to remove old tools before adding new ones and nothing was left in a weird state:
# Export ZFS Pool first - may need to switch to single user mode for this
zfs umount -a; zpool export <poolname>
# Remove old ZFS stuff
apt-get remove ubuntu-zfs zfs-doc spl-dkms
apt-get autoremove
add-apt-repository --remove ppa:zfs-native/stable
# upgrade time!
do-release-upgrade
apt install zfsutils-linux
#reboot
...and on reboot my zpools / zfs file systems all imported and mounted OK
tschundler
  • 161
FWIW, I have the same dilemma - although I'll probably wait until 16.04.1 before I take the jump.
From what I can see, Xenial simply includes native replacement libraries for the zfs-linux stuff, e.g. ZFS on Linux lists 0.6.5.6-1~trusty (et al); native 'buntu has 0.6.5.6-0ubuntu8.
So, I'm assuming that it could be viewed as a change in PPA as much as anything, with kernel support meaning no dkms rebuilding. But...
I was using zfs-fuse in 15.10 and updated to 16.04. As a backup measure I kept zfs snapshots. After reboot zfs-dkms was installed and my pool and file systems were recognized and mounted.
Apart from the speed improvement I haven't noticed any change.
Neko
I just updated from 14.04 to 16.04.1, and it definitely broke my ZFS, but not beyond repair. You'll need to make sure you uninstall all the old ubuntu-zfs and related packages (notably zfs-utils and zfs-doc) and THEN install zfsutils-linux from the 16.04 PPA defaults. It automatically imported my pools, and I'm back up and running again.
When I upgraded from Ubuntu 14.04 to 16.04, I also lost all file systems nested in the root. I decided as follows: Instead of a package ubuntu-zfs and zfsutils, was installed the package zfsutils-linux (not from PPA):
aptitude install zfsutils-linux
apt-get install -f
update-initramfs -c -k all
systemctl start zfs-mount.service
All file systems was mounted. After the reboot, everything is OK as well.
A bit off topic - since I've upgraded from 15.10 to 16.04 - we have several 15.10 Ubuntu servers with large ZFS filesystems - the systems are installed with standard filesystems (EXT4 I think?) and ZFS has been serving as backup repository on the side as secondary filesystem. ZFS was installed as per instructions here: https://wiki.ubuntu.com/ZFS
Upgrade procedure as we did succesfully:
  1. Normal apt-get update + apt-get upgrade + apt-get dist-upgrade + apt-get install update-manager-core + do-release-upgrade *As a result the ZFS was mounted and usable after the upgrade, but further action was needed
  2. To remove unncessary kernel adds/modules: apt-get remove spl-dkms *This removes old ZFS related stuff
  3. To further remove unncessary kernel adds/modules: apt-get autoremove *This also removes old ZFS related kernel stuff
  4. Upgrade ZFS feature flags (not sure if this is needed?): zpool upgrade
  5. Upgrade ZFS-POOL feature flags: zpool upgrade "your-zfs-pool-name"
  6. Reboot (just in case)
  7. DONE
I did an upgrade last night and followed tschundler's instructions.
I hit an error. When initially generating the initramfs and later on reboot, I got the error:
VERIFY3(range_tree_space(rt) == space) failed (3959080 == 16216391680)
PANIC at space_map.c:127:space_map_load()
When I got in in recovery, I could manually import the zpool. From https://github.com/zfsonlinux/zfs/issues/3370, I suspected a problem with the cache. When I tried in single user, I could see a process hanging:
/sbin/zpool import -c /etc/zfs/zpool.cache -aN
What sorted it for me was going into recovery and removing /etc/zfs/zpool.cache Annoyingly, to do this is recovery, I had to remount / rw - the process of which meant Ubuntu ran all the startup scripts and the zpool process hung again!
However, in the end, I (re)moved /etc/zfs/zpool.cache, rebooted and everything worked fine. Might file a bug against the zfsutils-linux package.
